Old 06-02-2014, 06:18 PM   #1
grs
Dash lites
How do the dash lites come out of a 64. Do they come out of the back side of the dash,or came I take the dash bezel off and pull then out? Does any one sell brighter ones?
grs is offline   Reply With Quote
Old 06-02-2014, 07:15 PM   #2
T2vigil
T2vigil's Avatar
Re: Dash lites
They come out from the back and they just pull out. I have found that if I take the plug and push left /right / up or down it will smap out. I do not know if anyone makes a brighter bulb. Good Luck.
T2vigil is offline   Reply With Quote
Old 06-02-2014, 07:18 PM   #3
corvettejim1968
corvettejim1968's Avatar
Re: Dash lites
I installed LEDs in mine and they look very nice. They are a whiter light and I got them on eBay
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 06-02-2014, 07:40 PM   #4
evan396
Re: Dash lites
Do you have a eBay link for the lights you got. Thanks evan396
evan396 is offline   Reply With Quote
Old 06-02-2014, 08:00 PM   #5
corvettejim1968
Re: Dash lites
it was a year ago but look under 194 led bulb i think
Old 06-02-2014, 08:34 PM   #6
grs
Re: Dash lites
I may try the aluminum tape. Is there any thing I could paint inside to make the lites brighter?
Old 06-02-2014, 07:55 PM   #7
tincan1966
tincan1966's Avatar
Re: Dash lites
The downside of installing the LED's is you loose being able to dim them, BUT since the most common complaint or reason to upgrade is because they are too dim...problem most likely takes care of itself. You can also freshen up the inside of the cluster housing with bright white paint and get rid of the green glow.
tincan1966 is offline   Reply With Quote
Old 06-02-2014, 07:59 PM   #8
corvettejim1968
Re: Dash lites
not my pics but great idea
http://i618.photobucket.com/albums/t...pse4006e54.jpg
http://i618.photobucket.com/albums/t...psfe6b69bb.jpg
http://i618.photobucket.com/albums/t...ps4ef3afb3.jpg
Old 06-02-2014, 09:51 PM   #9
MisterC
MisterC's Avatar
Re: Dash lites
I haven't done it yet, but many guys upgrade from the 194 bulbs to the 168's. They're about 50% brighter.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 06-02-2014, 11:55 PM   #10
Todd W. White
Re: Dash lites
Very simply put, all you have to do is run a dedicated ground all the way to your dashboard cluster, then, make sure you have a good connection between each socket and that ground, via the hole the socket plugs into. I have done this, and my dashboard is extremely bright. No problem seeing it at all.
If you really want better, brighter lights, check out M.A.D. Electrical's website, and upgrade your grounding and power systems.
Todd W. White is offline   Reply With Quote
