06-03-2014, 01:34 AM | #1 |
eaton ho52 question
Have a c20 with an eaton ho52 rear end it makes a clicking noise when you go around corners is this normal for this rear end ? Ive read some articles that say its normal for the eatons to be noisy but should it really be clicking?
06-03-2014, 09:52 AM | #2 |
Re: eaton ho52 question
does it have a no-spin locker? if going around corners, that is simply the locker locking and unlocking
06-03-2014, 10:28 AM | #3 |
It is thanks for that puts my mind at ease. Thought it may be going out but glad its not.
06-03-2014, 11:54 AM | #4 |
If this sound is something new, it is possible the differential oil needs changing.
06-03-2014, 02:54 PM | #5 |
Nothing new and just changed the fluid 2 weeks ago must just be the locker.
06-03-2014, 03:05 PM | #6 |
I don't know much about the Eaton lockers. But, do they require addition of friction modifier like the new posi and locking axles do? It might be worth a try.
06-03-2014, 03:08 PM | #7 |
Carpe manana
I don't believe so - IIRC the additive is for clutch type posi carriers which the HO52 locker is not.
06-03-2014, 03:10 PM | #8 |
I was just going to suggest that. I kknow they need an additive, maybe another board member will chime in on a good additive. They should available at and parts house near you
06-03-2014, 03:27 PM | #9 |
Like stated before, the HO52 doesn't require additive because there are no clutches. The additive is friction modifier for clutch material. The HO52 is a mechanical locker.
