Soft top clearance HELP!!!
Need some soft top help here guys!!! I’m looking for some pictures of how much clearance there is between the bottom of the canvas top and the sun visors. I’m currently installing a full roll cage and I need to determine if I can put the front overhead cross bar on top of the sun visors or behind the visors. The factory hard top has enough clearance that I could put the cross bar above the sun visors I’m just not sure if the soft top has that same clearance. Any help would be greatly appreciated!!!
Thanks, Eric |
Re: Soft top clearance HELP!!!
I'll post some pics when I get home tonight if someone else hasn't by then.
Is this what you need? Looks like 2-1/8" all the way across. Let me know if you need more pics.
#5 | |
Thank you so much for the help!!! Eric |
Here is a pic of the front attachment location. Mine uses the lower screw of the weatherstripping to attach.
SKINNY TIRES RULE!
If you can get the hard top on with a roll cage, you should be able to get the soft top on too.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
unfortunately not, I'm finding out. The center of the soft top is at the same height as the hardtop however the sides taper down lower to the bed rail than the hardtop. So it looks like I'm going to have to drop the roll cage 2 inches lower to fit under the side of the soft top.
SKINNY TIRES RULE!
Hum, interesting. Make sure you post pictures when you get it completed.
