Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-07-2014, 09:05 AM   #1
Witt1962
Wider rear wheel wells.
Just starting at the back of the truck. I know I should stop now.
This truck will need some more tire to hook up the big block.
The plan is to run a ford 9 inch and stock control arms. I will be running at least 29.5x 10.5 slicks or 315/60s on about a 6 inch drop.
What are you guys doing about the wheel well restrictions?
This truck is a 1970 fleet side, wood bed.
Witt1962 is offline   Reply With Quote
Old 06-07-2014, 11:17 AM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Wider rear wheel wells.
Mine are made from two sets of inner fenders cut and welded to make one set that are widened to the frame rails.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-07-2014, 11:46 AM   #3
Witt1962
Great idea. I didn't want to weld in a middle strip to the current wheel wells.
Old 06-07-2014, 12:44 PM   #4
vidman
vidman's Avatar
I just used 4 to make 2..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-07-2014, 02:53 PM   #5
71Dragtruck
Mine.
Sponsored by:
Hard Candy Customs
Old 06-07-2014, 03:52 PM   #6
tinydb84
tinydb84's Avatar
Love the stock look of those wheel wells!
David
Instagram: myfabguy
Old 06-10-2014, 07:07 PM   #7
scatesracing
Machinist
scatesracing's Avatar
I did the same thing! Just welded two together. Took them all the way to the frame rail.
scatesracing is offline   Reply With Quote
Old 06-10-2014, 08:24 PM   #8
Witt1962
Thanks everyone and thanks for the pictures.
Old 06-11-2014, 11:40 AM   #9
skeeterbug
skeeterbug's Avatar
Ditto took 4 to make 2 lol.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 06-11-2014, 01:50 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
I also used 4 to make two - my originals spliced together with a pair of damaged ones that the owner was going to toss out…
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-11-2014, 02:46 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I won't be running out of width any time soon.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-11-2014, 02:54 PM   #12
Marv D
Registered Truck Offender
Marv D's Avatar
Yup I was going to glue 4 together to make wide ones,, then decided the wood and stock frame was too heavy for my faster faster faster addiction (and lack of motor to make the 'fast' I craved)
So I took the easy, cheap and light way out. Alstons tubs and a bunch of 0.035" aluminum from the local metal shop.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-11-2014, 04:16 PM   #13
vidman
vidman's Avatar
Thats one of the best looking As^,s I have seen in a long time
Old 08-11-2014, 02:00 AM   #14
ItsRandy
ItsRandy's Avatar
Hey Marv...what is your roll bar/cage good to going through thr bottom part of the cab instead of the top of the cab? What tires are those you are running?
ItsRandy is offline   Reply With Quote
Old 06-12-2014, 10:42 AM   #15
Hart_Rod
Hart_Rod's Avatar
Here's mine:
Hart_Rod is offline   Reply With Quote
Old 06-15-2014, 03:48 PM   #16
70blackfish
I fit a pair together, fits 29/15/15 tires on 12" wide steel rims...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 08-01-2014, 11:43 PM   #17
MONTE
MONTE's Avatar
I got 29/18/15 on mine.
MONTE is offline   Reply With Quote
Old 08-09-2014, 05:03 PM   #18
vidman
vidman's Avatar
Hey Monte what are you running for back space on the 15s.. any pics of your set-up
Old 08-09-2014, 10:52 PM   #19
ItsRandy
ItsRandy's Avatar
I also spliced 4 to make 2.
Old 08-12-2014, 06:33 PM   #20
moggey01
Going to fab tubs from sheet aluminum. Have to make them pretty big to clear my tires at ride height.. I think 4inches above the tire is safe . Tire is a 32x17.5 on a 14wide wheel . Tread width is 15 but M/T calls them 17.5. Still using a stock frame but its real close.
moggey01 is offline   Reply With Quote
Old 08-12-2014, 06:53 PM   #21
moggey01
o sorry ,Mine is a stepside, the bed is raised on the frame about an inch 1/2. The steps are moved up on the bed box 1 inch. This gaines over 2 inches with a tall tire (32"). You should have more room with a fleetside I think. The wheel opening is stock ,just lowered the body line back down 1 inch. Ride heigth is 6"
