Old 06-07-2014, 05:57 PM   #1
dwcardfan
dwcardfan's Avatar
2010 Camaro exhaust manifold
I am needing gaskets for my 2010 camaro exhaust manifolds. The local parts stores are having a hard time getting the right ones. Does anybody have a part number for the 2 hole flange gaskets between the manifold and flange? My flange has a circle groove cut in it and has 2 bolts.
dwcardfan is offline   Reply With Quote
Old 06-08-2014, 08:07 AM   #2
dwcardfan
dwcardfan's Avatar
Re: 2010 Camaro exhaust manifold
Here is a pic of the exhaust pipe.
Old 06-08-2014, 09:32 AM   #3
dayj1
GM shows part number is 92202326. The "local-parts-store equivalent" is Fel-Pro 61431. But that's a flat gasket with 2 "ears".
With that groove that you show, it sure looks like it would take a ring type gasket. I searched RockAuto just for grins and they show Fel-Pro 61012 which is a ring type seal.
dayj1 is offline   Reply With Quote
Old 06-08-2014, 12:05 PM   #4
dwcardfan
dwcardfan's Avatar
Thanks dayj1. That felpro 61431 or g1050 is suppose to be the same is what the parts store ordered but it was a bigger diameter than my flange. The bolt holes were to far apart and would not line up. I might try the ring style gasket. I bought these manifolds on eBay and they where supposed to be 2010 Camaro.
Old 06-10-2014, 12:07 AM   #5
Blackpony
Blackpony's Avatar
post a pic of the manifold.
Blackpony is offline   Reply With Quote
Old 06-10-2014, 07:25 AM   #6
truckdude239
truckdude239's Avatar
That's the ring style gasket
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-10-2014, 11:57 AM   #7
dwcardfan
dwcardfan's Avatar
Manifold is smooth. I will try to get a pic this evening.
Thanks truckdude. Do you mean just the chrush ring without the 2 hole flange?
Old 06-10-2014, 01:34 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Strange, as different places give different results. Rock Auto only lists 1, the regular crush-fit gasket like some of the trucks use.
But Summit shows the 2-bolt "flat" gaskets with all of their mid-pipe kits.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-11-2014, 05:11 AM   #9
jamesjones
Freakin Awesome!
jamesjones's Avatar
It should be the GM part number listed earlier in this thread...
http://www.gmpartsdirect.com/catalog/frameset.cfm
I'll see if my gaskets have a PN on them when I get home in the morning though.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 07-02-2014, 01:00 AM   #10
dwcardfan
dwcardfan's Avatar
Well I took a shot in the dark and had oreilly's order a 2008 pontiac g8 exhaust manifold to pipe crush gasket and it was the right one. Thanks for all the help guys. Here is the Fel-Pro number if anyone needs it #61519
