Header bolts size
Ok one of the 100 little things I need to do is find some header bolts as I lost the manifold bolts when they were taken off and for some reason I cant seem to find them or at least decently priced ones. I have found some online but they dont say the size or thread pattern, I know they are metric Im thinking M8x1 or 1.25 does anyone know the size I need for my 07 5.3 ? and where to go to get some ? I went to the local Home Depot but all they had was SAE grade 8 not in metric tho...I refuse to pay the 30-60 bucks that these places i found want. they are just freaken bolts, somewhere there has to be a place I can go to find these at a reasonable price... thanks for any help oh and I am going with some shorty headers if that makes a difference
Trying to get thru my LS swap ![]() |
Re: Header bolts size
What I am finding it is an 8mm x 1.25 thread. Hit up lowes or home depot you should be able to get them for a couple bucks.
Thanks that's what I was thinking but wasn't sure
meowMEOWmeowMEOW
btw you can get a set of 12,16 or 17 in that size from Afco for under $10
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | ||
Thanks everyone now that's one less thing I need to worry about
#6 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#7 | |
meowMEOWmeowMEOW
![]() Join Date: Sep 2005
I ordered mine from advance auto from Dorman products they are coated in something g that makes them look gold and is suppose to help them from seizeing in the heads and breaking
Thanks guys for the help, going to check ace hardware, I didn't even think about them. Truckdude I have antiseize in a tube but thanks for the advice
meowMEOWmeowMEOW
Isn't the goldish color zinc?
I have a set left over, from a set of Hooker shorties....I used studs/ nuts on mine? Yours for the mail price, but it may take a few days, from my spot in Illinois, to yours in Cali? They are black oxide bolts, nothing special....if you want them,I don't need anything , but the mail charge
#12 | |
meowMEOWmeowMEOW
![]() ![]() ![]() ![]() ![]() ![]() Now, ![]()
#13 | |
#15 |
#16 |
meowMEOWmeowMEOW
Ya, thats what anti-seize was for...but most of us forget it. Thats also why the stud-style replacement has gotten more popular, as its much less likely to sheer at the nut.
#17 | |
#18 |
yeah I've had like 4 now in the coupla motors ive messed with
they're pretty dang easy to get out at least |
#19 |
![]() Join Date: Oct 2013
I went with stainless bolts. not as common, as they're metric, but they are out there and should hold up pretty good.
#20 |
![]() Join Date: Dec 2012
Anybody know where to get a good set of studs for the manifolds, I cant seem to find many of them.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#21 |
meowMEOWmeowMEOW
#22 |
Thank you sir, that is exactly what I was looking for.
#23 |
updates? lol
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#24 |
Got my heads back and installed. We got most of the wiring done and computer hooked up sprayed some starter fluid inside the intake and it fired up for a couple of seconds
#25 |
That should only take about a hour aye??
