![]() Join Date: Nov 2011
WTB OEM style 4 bbl. air cleaner housing
I've got a 350 sbc with a edelbrook 4 bbl. and high rise manifold- would like a stock looking air cleaner housing- I don't think I need/want the spacer but want to make engine look more stock- without swapping manifold and carb. Please PM me if you think you have one- not looking for perfect-or expensive...
Just like to part out trucks!!
Re: WTB OEM style 4 bbl. air cleaner housing
I've got one out there $25 for air cleaner and $20 for spacer plus shipping. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Randy, Sounds good. Got any pictures? I don't think I need the spacer but I'd like to know the diameter of the hole in bottom piece just to make sure it fits my carb. Unless you already know it will fit my edelbrook 4bl. Appreciate the fast response to my thread.
I'll get some pics later today and measure it. It should fit your carb, I got a edel on my 67, I will make sure. Thanks Randy
![]() Join Date: Feb 2014
This set up will work great for a 2 WD. The combination of the high rise with the spacer will not work in a 4 WD. It is too tall and because the engine is set closer to the firewall the assembly will hit the cowl. I had to section me spacer by 1.5". Good luck, Bruce
#6 | |
Phil, sorry ran out of time last night, had boys ballgames. I will try today
Thanks Randy
Phil, I have a holley, I forgot I changed it out, it doesn't fit it
Randy, So you think the stock housing won't fit the Edelbrock too? If you don't know I think I'd take a chance on the hope that it will.. also I might be able to make it fit. Let me know your thoughts- Phil
jjzepplin, I think it will with the spacer, I will check it out on Fri
Phil, if your Edel is like the holley it wont fit unless I find out the spacer will help it. I will try it Fri afternoon Thanks Randy
Randy, Ok, I'll wait till I hear back from you- thanks for trying-
So a stock filter doesn't fit a Holley even with the spacer? There goes my plans too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I have a high rise and it hits so if you don't have a high rise I think it would fit with spacer
#15 |
Randy, I do have a high rise- but does the space reduce or enlarge the opening to the air cleaner? I think if it reduces it(so that it fits the carb. I might be able to rig a filler ring... or maybe cut a larger opening if it enlarges-- what do you think?
#16 |
the spacer is the same size I think, you could cut it down possibly , the air cleaner hits without out, but like a 2 inch spacer would be enough
#17 |
I see.... the bottom of the air cleaner housing is concave... that complicates things-- Better i hold off and see what else I can find. Many thanks for all your time and effort. I may get back to you if I get desperate. Phil
#18 |
#19 |
I had a chevy astro van I think early 90's with fuel injection that had a shorter spacer than the trucks without a pcv outlet. it was the same diameter just shorter. It may work for you.
#20 |
#21 |
pm returned, Thanks
