Old 06-10-2014, 11:49 PM   #1
Jake Wade
Jake Wade's Avatar
SEM interior paint/dye
I need to repaint my door panels on my 85 GMC. It is the factory blue.
Does this match pretty well?
http://www.classicparts.com/1973-98-.../#.U5fQVyIo6M8
I have also seen the colorbond brand.
Hard to tell looking at the paint chips online whether or not the color is right
Jake Wade is offline   Reply With Quote
Old 06-11-2014, 01:34 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: SEM interior paint/dye
I'm actually trying to tackle this issue right now in my blazer.
As I recall when I went into napa they had SEM dark blue there but it didn't look to match very close at all to the blue of my trim panels.
I will look into getting some colorbond and see if I can figure this out unless someone else has gone through this trouble?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-11-2014, 07:25 AM   #3
Jake Wade
Jake Wade's Avatar
Let me know if you find a good match, I will do the same.
Old 06-11-2014, 07:33 AM   #4
BigMike608
BigMike608's Avatar
SEM Shadow Blue, my interior is the same dark blue and it's a perfect match. I did mine about 2 years ago. I bought the SEM Shadow Blue Color Coat at my local paint supplier (English Color) for $12 per can. Cleaning and prep is the most important step. First I mixed in Clorox with a large bucket of very soapy water and used a scuff pad to clean every inch of each piece and then rinsed thoroughly. I repeated this process 4 times for each piece. Next I dried off each piece with a lint free microfiber towel. Then I thoroughly cleaned all pieces once again using automotive grade lacquer thinner making sure to only wipe in one direction to keep from spreading the leftover residue. After all this was complete, I let everything sit and dry for 24 hours. Once it was ready for paint I did 2 light coats of Bulldog adhesion promoter with 5 mins between coats. Finally I used the SEM color coats and sprayed 6 lights coats on each piece with 5 mins flash/dry time between coats. I let everything set for a few days to make sure it was completely dry before I begin re-installing.
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 06-11-2014, 12:24 PM   #5
Ski-me
Ski-me's Avatar
Cleaning/prepping is key!!
I scrubbed and scrubbed my new dash before painting. Still got a little de-lamination at the corner of the instrument cluster. Everything else looks good but didn't like to see that when I first installed the dash.
It has to be super clean....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 06-11-2014, 08:27 PM   #6
Jake Wade
Jake Wade's Avatar
Thanks for that info!
This the one?
http://www.summitracing.com/parts/smm-15043/overview/
Old 06-12-2014, 05:19 PM   #7
INSIDIOUS '86
This the one?
This is SEM shadow blue compared to my 91 k5 interior blue.
Old 06-12-2014, 08:42 PM   #8
Jake Wade
Jake Wade's Avatar
Looks a bit dark, eh?
Old 06-11-2014, 10:43 AM   #9
INSIDIOUS '86
Hmm I will look for shadow blue and let everyone know how it looks. Doing a 91 k5 interior here myself.
Old 06-11-2014, 10:52 AM   #10
slowcpe
slowcpe's Avatar
Not sure on the color match but I used the SEM product on my seat and was very impressed with the turnout. I went with black though.
I bought mine from a auto paint supply store and they carried just about every color in stock.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 06-11-2014, 09:58 PM   #11
INSIDIOUS '86
From a google images search it looks correct.
Old 06-12-2014, 09:01 PM   #12
BigMike608
BigMike608's Avatar
its a bit darker because the original pieces have faded over the years.
Old 06-13-2014, 03:42 PM   #13
INSIDIOUS '86
I don't think the paint underneath the trim faded this light. Front and back on all my trim match. I've used SEM on many other things and they match even better to other faded colors. I think this tint of SEM is not a good match although it's better than any other blue they make. I'm going to try some colorbond but I will run this in the meantime.
Old 06-13-2014, 10:46 PM   #14
rs74
rs74's Avatar
Gmachinz has a build thread showing what he used on his blue interior. http://67-72chevytrucks.com/vboard/s...=548970&page=2
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-14-2014, 08:08 AM   #15
68Timber
I know the pieces fit
68Timber's Avatar
If only SEM made the medium blue. It's pretty aggravating to own an interior color SEM doesn't sell.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-14-2014, 05:00 PM   #16
INSIDIOUS '86
You think color bond has a match?
Old 09-02-2014, 08:03 PM   #17
Corts60
Just here to tinker
Corts60's Avatar
I hear you on that. I can't find anything that matches my Holly Green interior.
Old 06-12-2014, 09:06 PM   #18
beamn7
I used the Shadow Blue as well on my 85. Perfect match. Be sure to use their prep/cleaner first.
beamn7 is offline   Reply With Quote
Old 06-14-2014, 05:27 PM   #19
LEEVON
Moderator
LEEVON's Avatar
x2 on the medium blue...supposedly there is a corvette blue color that is a close match but I've not seen anything in the standard colors that match. I had it custom matched one time, that worked ok but it take more time and more money.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-02-2014, 02:18 AM   #20
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do we have more pics of Shadow Blue, or the other SEM Blues?
I'm trying to see what blue I'd like to go with.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-02-2014, 02:30 AM   #21
LostMy65
LostMy65's Avatar
It's weird how different camera shots in different lighting changes the look of Shadow Blue.
Here's a thread from another forum with lots of pics;
http://www.celicasupra.com/forums/sh...tion-True-Blue
Old 09-02-2014, 03:11 AM   #22
Skunksmash
Skunksmash's Avatar
When I took the door panels off my original 1 owner 82 silverado, they were that dark color behind it. Of course that's an 82, but a lot of the stuff had faded to that other color that you're showing. Such as the parts that hold up the headliner, and other stuff that was exposed to sun. That color may not be an exact match but its pretty close. Its easy to be fooled when not in direct sun and by other people's cameras and your monitor
Skunksmash is offline   Reply With Quote
Old 09-02-2014, 08:34 PM   #23
hatzie
Moderator
hatzie's Avatar
You won't go to Wal Mart or AutoZone to buy this kind of stuff.
A buddy had the Smyth Automotive paint store in Cincinnati mix a color in SEM dye. He needed to color match some replacement interior parts, on his project '88 Supra, to the originals. They were a really dark red and the rattle cans just didn't match well enough. He sprayed it through a regular paint gun.
You should be able to do the same at any large automotive paint store.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-02-2014, 09:14 PM   #24
Ski-me
Ski-me's Avatar
I brought in my old dash and found a spot that was mot faded....had the paint shop color match with vinyl paint. Cleaning the pad beforehand is the most critical! It must be super clean to stick properly.
- Jeff
Old 09-02-2014, 09:32 PM   #25
Ski-me
Ski-me's Avatar
- Jeff
