06-11-2014, 01:43 PM | #1 |
rear sway bar
Whats up c10 family... i wanted to see if y'all could help me..where can i get a rear sway bar for my 68..did they make these trucks with rear sway bars from the factory....or is this strictly an aftermarket product..your info would be much appreciated...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
06-11-2014, 01:48 PM | #2 |
70+ ( Old Skool Club )
Re: rear sway bar
Thay never came on a C10 from the factory and I'm pretty sure not on the
C20's and C30's as well but can't be 100% sure on that one. I know Addco and Hellwig make rear sway bars for our trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-11-2014, 02:20 PM | #3 |
Re: rear sway bar
Camaro rear sway bars will work and work real well if you have coil springs instead of leaf springs. Do a search here and find the post I don't have it saved and aren't computer savvy enough to tie links together. I think it may be in the truck tech or the FAQ's on the top of the page in the upper left hand corner. Look there first, you should spend some time in there any way. Jim
06-11-2014, 05:18 PM | #4 |
Re: rear sway bar
rear sway bars not a factory option at anytime
they are readily available from jcwhitney lmc broters and all the local vendors can get them for you
06-11-2014, 05:58 PM | #5 | |
Re: rear sway bar
06-11-2014, 06:58 PM | #6 |
Re: rear sway bar
67-72 conventionals "C" or "K" trucks were not offered with rear stabilized bars. However from 68-72 the P30 SRW step vans did, something to to look into if you see one at a yard. Of course the later 73 up pickup trucks C20-30 offered rear stabilizer bars as part of the Z81 Camper Special equipment packages.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-12-2014, 12:48 AM | #7 |
one set closer
Re: rear sway bar
06-12-2014, 10:35 AM | #8 |
Re: rear sway bar
late eighties camaro and firebird cars work good .i have the firebird ones on mine i will post some pics tonight when i get home. easy install just drill a few hole and bolt up
06-12-2014, 01:06 PM | #9 |
Re: rear sway bar
I have an IROC Z bar in mine. It was the biggest that the General used for these cars. I have dropped the rear 4.0 and the front 3.0 and also run a 1.25 bar up front.
Using KYB shocks this truck is more fun to drive than my Vette |
06-12-2014, 01:56 PM | #10 |
Re: rear sway bar
More fun than two Vettes?
I have an Addco front and rear on my Suburban. Since my exhaust runs where the rear should have been mounted, I modified the mounting. No pics, the Burb is at the shop.
06-12-2014, 03:17 PM | #11 |
Re: rear sway bar
Nice looking Vettes.
I believe the Iroc Z bar is 25mm., use along with a 1.25 bar used on c20/30 trucks up to 87.Poly mounts and new poly cab bushings will make it handle decent. Rob from No Limit makes a great kit and has some great advice on how to set up these old trucks. Mine is set up as a cruiser but handles decent for what it is.... A long bed POS with a 496. |
06-12-2014, 06:45 PM | #12 |
Re: rear sway bar
Mine is a Hotchkis bar for a 1980's Camaro. Found it on the parts board for cheap. Pics are in this post: http://67-72chevytrucks.com/vboard/s...&postcount=121
I had to modify a bit to make it mount up nice. Its not perfect, the links should be vertical, but to fit and miss everything I had to angle them. It does stabilize the truck a lot, especially on highway on ramps. It has a weird feel to it, when you corner hard you can feel the rear of truck sort of lift up. Feels like its going to skid until you get used to it. The bar does limit the amount of power you can apply in a corner without losing traction.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
06-12-2014, 06:52 PM | #13 |
Re: rear sway bar
I thought I read on the "make it handle" thread that No Limit had a rear sway bar but I can't find it on their website. I'm interested in running one too.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
06-12-2014, 08:00 PM | #14 |
Re: rear sway bar
I have front and rear from CPP. I have heard that one should not use a rear one if truck is lowered. Anyone know if this is true and why? Mine is not on road yet so I don't know. Good luck.
06-12-2014, 08:27 PM | #15 |
Re: rear sway bar
don't know what you are referring to about lowered trucks and no sway bars.
Like stated mine is lowered and I have no issues. Run a bigger bar in the front to help balance out the truck. The Iroc bars mount to the rear axle and have end links that mount to the frame. Keeps everything nice and tight out of the way. When you do lower make sure you change the track arm or sometimes called a panhard bar I use an adjustable one. |
06-12-2014, 10:03 PM | #16 |
Re: rear sway bar
here is a pic of my swaybar
06-21-2014, 08:47 PM | #17 |
Re: rear sway bar
nice...so did you pull all the brackets from the fbody and used them on your truck
06-21-2014, 08:56 PM | #18 |
Re: rear sway bar
also..how did you know where exactly to install them...
06-12-2014, 11:48 PM | #19 | |
Re: rear sway bar
I still want to get a fatter bar for the front.
06-13-2014, 05:20 AM | #20 |
Re: rear sway bar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual Last edited by Liz; 06-13-2014 at 04:24 PM. Reason: .. |
05-30-2021, 01:43 PM | #21 |
Re: rear sway bar
We used the rear sway bar from CPP works great! My truck is lowered 2 1/2 in the front a 4 in the back
06-01-2021, 05:56 PM | #22 |
Re: rear sway bar
I used the Hellwig rear sway bar on a GMC I built a few years ago. You can definitely tell its there, but just be forewarned it will cause the truck to be really tight feeling overall, and at times make it feel like it's pushing a little bit. I guess by locking down the rear with the swaybar in place it doesnt allow the front to plant and take a bite (?) Maybe I could have had the front springs too tight .. I'm no pro. I had Hotchkis springs on the truck. All I can tell you is it was on rails. The rear bar is definitely worth the investment if the rest of your truck is setup accordingly.
06-02-2021, 01:31 PM | #23 |
Re: rear sway bar
The 3rd and 4th generation F-bodies use the same rear sway bar with differences in mounting. In addition GM used numerous sizes over the years. This means that not all Trans Am's, IROC's and Z-28's have the same size bars. Some years there were more than one size depending on the various packages offered by GM. That being said the size differences are only 3 to 4 MM of each other for the performance cars so you may not need to search for the absolute largest one.
When I got mine there were 4 to choose from in the wrecking yard. Fortunately I was armed with knowledge and calipers so and I got the largest bar in the yard for my Burban.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-05-2021, 03:39 AM | #24 |
Re: rear sway bar
Finally had my Hellwig installed on my C10 long fleet and on the 60 mile drive home after installed can tell the difference in handling. Truck is overall tighter in handling if that makes sense.
06-05-2021, 01:01 PM | #25 | |
Re: rear sway bar
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
