Old 06-15-2014, 01:36 AM   #1
suburban99
suburban99's Avatar
62 with a 78 front end questions.
For anyone running later model disc brake front end (mines a 78): Where did you attach the shock mounts to the frame? Is this power steering box 62 vintage or 78 vintage.
suburban99 is offline   Reply With Quote
Old 06-15-2014, 11:38 AM   #2
informi
Re: 62 with a 78 front end questions.
I am still working on putting a 84 front end under my 62 so can't speak to the shock mount from personal experience. But there is a good write up by Markeb01 here: http://67-72chevytrucks.com/vboard/member.php?u=29594.
It shows where he moved the upper shock mount.
The steering box looks to be the newer 73+ type.
informi is offline   Reply With Quote
Old 06-15-2014, 02:30 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Here's the thread pertaining to my front suspension swap. Although I failed to show the finished shock installation, it does show how far the brackets needed to be moved to line up correctly. If I can help with any other question just let me know. Good luck.
http://67-72chevytrucks.com/vboard/s...ont+suspension
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-15-2014, 04:05 PM   #4
siggyfreud
siggyfreud's Avatar
I'm guessing its a different situation for 63-66?
siggyfreud is offline   Reply With Quote
Old 06-15-2014, 05:28 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes. 63 and newer frames are different. The late suspension goes right into them and the shocks bolt up to the original mounts without mods. The 62-down guys have it harder since they have the old torsion bar arrangement type of frame.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-15-2014, 05:37 PM   #6
suburban99
suburban99's Avatar
Removed the control arms to replace upper and lower bushings. Also coating whole frame with chassis saver. Hardly any rust! Green rubber garden hose used to hold the alignment shims in place. Bushings are a real dog to remove.
Old 06-16-2014, 01:00 AM   #7
Captainfab
60-66 Nut
If the steering box accepts inverted flare fittings it is a '68 to about '80. If it accepts metric with O-ring fittings it is a '81-'91 steering box.
Old 06-15-2014, 04:36 PM   #8
Softpatch
Softpatch's Avatar
thats a late model Power steering box 1972-78
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
