Old 06-15-2014, 03:34 AM   #1
bpatrol
couple ls swap questions
I am in the process of putting a ls1 in my 67 c10 and it will have a fast ez efi on it.
what pedal are you using and cable?
Any suggestions on what length I need?
pics would be great.
Also are people using the 73- motor mounts or 67 ones?
this is the only parts I haven't thought out.
phillip
bpatrol is offline   Reply With Quote
Old 06-15-2014, 10:59 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: couple ls swap questions
On my '68 I swapped it to the later model ('72 in this case) pedal, bar and cable assembly. Then to get the carb connection right I wound up using a universal Lokar piece for the cable connection. Or by Fast Easy EFI instead of the carb style replacement you mean the wireless/fuel rail/ecm all in one combo that uses a standard efi throttle body?
I tried the ECE mounts that use the later '73 up style mounts but IIRC it left everything too far forward so I wound up using '67-'72 small V8 mounts coupled with standard motor mounts bolted to LS swap plates from TransDapt.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-15-2014, 02:32 PM   #3
truckdude239
truckdude239's Avatar
I used dirty dingo mounts that allowed me to use the stock 71 engine mounts
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-15-2014, 03:12 PM   #4
bpatrol
thanks for the info
The fast efi I have setup is like a carb so no fuel rails.
Old 06-15-2014, 11:42 PM   #5
uxdesigner
In also used the stock mounts with CPP sliders, for perfect. See build for pics...
uxdesigner is offline   Reply With Quote
Old 06-16-2014, 09:47 AM   #6
Hart_Rod
Hart_Rod's Avatar
Phillip - there's a lot of good infor on LS swaps in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=566743
Hart_Rod is offline   Reply With Quote
Old 06-16-2014, 11:31 AM   #7
Amr84ss
I used the Lokar pedal assembly and one of their cables, for my 68. I have an car intake on mine so I cant help with the length.
I am using factory mounts with conversion plates. (non adjustable)
Amr84ss is offline   Reply With Quote
