06-15-2014, 03:11 PM | #1 |
64' K10 Project Long Bed
Grandson visiting and we are getting ready to start his 1964, K10 project. We are looking it over, not a lot of rust, cab has a little on right side floor in kick panel area, and door bottom pinch weld gone on both sides, bed pretty good, however, brace at left wheel well has punched through side.
The frame and drivetrain not very rusty, think it has been AZ truck, built in St. Louise. Drive train on initial look appears original. Missing front drive shaft. Two tone paint. Overall sheet metal looks good. The frame and cab ID show it to be an original K truck, with two tone paint. This intended to be a two to three year project as grandson is freshman in HS, and I am 65. He plans to drive it some for fun would be second vehicle for him. Kind of thinking need to evaluate the drive train, trans, transfer box, diffs as part of first stage of projects. Also thinking the cab restoration would be another first step. Sure we will be looking for lots of help as we start project. Les |
06-15-2014, 03:23 PM | #2 |
Re: 64' K10 Project Long Bed
KOOL I look forward to yalls build, I too have a 64K10 though ,mine is not factory 4x4. It's sitting on a 70's 4x4 frame. There are lots of good builds on here. Never get tired of lookin... I will be subscribed..
1964 BBC 402 4x4 |
06-15-2014, 06:01 PM | #3 |
Your grandson's truck looks solid and a great starting point for his build. Good luck and I hope you guys have a lot of fun working on it. It is great to see a young kid interested in these old trucks.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
06-15-2014, 08:22 PM | #4 |
Randy, Owen
Thanks for encouragement, will look at other builds for knowledge on how to restore it. Any specific suggestions on builds to learn from? It does appear to be a solid truck with just a little rust in a few areas in the cab, along with a few small dents here and their. Have no knowledge of drivetrain condition yet, plan to take a closer look this week. Happy it is a two color paint truck. Les |
06-15-2014, 08:28 PM | #5 |
One foot in front of the other
Welcome. Sounds like a great project.
Here is a link to Tony Smith's truck. He is no longer on the forum, but does some good work. http://67-72chevytrucks.com/vboard/s...d.php?t=382290 |
06-16-2014, 11:00 AM | #6 |
Welcome aboard! Looks like a great start! 4X4's are always cool! Have fun! I'm Sub'd.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-16-2014, 12:15 PM | #7 |
Cool project....can't wait to see more pics and progress!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-17-2014, 06:55 PM | #8 |
Thanks everybody for the support on new projects. Plan is to document current condition and probably ask a lot of questions. Assessing and recording everything before disassembly for now. Kind of cool mud flaps from back then.
06-17-2014, 07:00 PM | #9 |
Dana 44 front axle tag picture. Looks like it has 3:73 axle gears, which was standard for K10s from research.
06-17-2014, 07:36 PM | #10 |
yep you don't see many of those tags still on there..
1964 BBC 402 4x4 |
06-19-2014, 12:48 PM | #11 |
another one saved!! nice truck.
1961 chevy K10 my build is------------61K10 build |
06-22-2014, 09:32 PM | #12 |
A few more pictures of truck, first the front fender date codes, did they use different numbering? Pictures of the codes stamped in front fenders.
06-22-2014, 09:39 PM | #13 |
some pictures of the seal/weather strip for the fender and inner fender, will get some better pictures when disassembling later.
06-24-2014, 02:34 PM | #14 |
Les, Glad to see you are finally starting to get into this truck. I still can't make up my mind if I want to build my '65 as a K20 or swb flt lowered truck. I can't even start until I get my canned ham camper done. Truck looks great by the way. I know you have been building that 292. Upload some of those pics when you get a chance. I will checking this one often for updates.
06-24-2014, 09:45 PM | #15 |
X2 on checking often fer updates! Especially since I heard something about a 292!!!! I have 3...they're awesome engines.
06-24-2014, 11:45 PM | #16 |
Thanks for the encouragement, plan to get the 292s out next week and our grandson will take apart one of them as his first engine overhaul. The other we will try to start.
FYI , found the following Chevrolet Part Illustration and information manual, nice expanded views of parts/components, along with information like axle ratio codes, etc. I need more review of it and will post more types of data/ information contained. |
06-25-2014, 06:08 PM | #17 |
A little more detail on the above catalog content.
06-26-2014, 01:22 PM | #18 |
Neat book Less, I would like to take a look at the 4x4 pages. I am going to try to adapt my ho52 rear end with brakes from a 14bolt rear, Since you can't find brake parts anymore for the 3/4-1 ton rear ends.
06-29-2014, 05:24 PM | #19 |
Brian,
Sure about looking at book any thing special, I can try to send images to you. Les |
06-29-2014, 05:38 PM | #20 |
Josh and I have been cleaning up space for room to take 64 apart.
Using a new engine stand that is working very nice, below are pictures. Very strong and no engine sag. Also the extra wheel helps, wo/ hindering moving the engine. It is a torin part number T26801. The engine is a 1965, extra 292, that we are going to take apart and save for future part needs. Les |
06-29-2014, 06:16 PM | #21 |
Kewl I see a 292. I'll be lookin..
1964 BBC 402 4x4 |
06-29-2014, 07:41 PM | #22 |
Sweet truck! I really want to build a k10
06-30-2014, 08:56 PM | #23 |
Josh and I starting to disassemble an extra 1965, 292 engine purchased used. Seller said the engine was from a low mileage ambulance. So far, the cylinder head is off and the cylinder walls show no signs of ridge wear. Have not looked at a the cylinder walls yet, but quick looks good so far.
Question, the 292 engines typically have a wear ridge at the top of cylinders where rings stop? Still evaluating engine, and need to make decision on, whether to keep as whole engine or save for parts. Original plan was for it to be a parts engine, however, looks to be in good condition so far. Going to take the oil pan off tomorrow. What do you think, could the rings still be good? Les thanks, Les Last edited by aotte1; 06-30-2014 at 08:58 PM. Reason: edit words |
06-30-2014, 09:59 PM | #24 |
I can still see some milling marks on the cylinder wall...long as there are no cracks or major issues with the block you'll be fine...have it tanked, magnafluxed, and checked for cracks. More then likely a low mileage engine will be fine.
07-01-2014, 08:25 AM | #25 |
I'm checking in from time to time good to see you making progress.....
1964 BBC 402 4x4 |
