06-15-2014, 11:22 PM | #1 |
My bed is crooked
So the bed on my truck does not sit level with the cab. The front of the bed is lower by an inch about. The wood is not in it, but is there something missing like a spacer or bushing? The cross bars of the bed sit right on top of the mount. Im sure this has been asked before but i dont know what to put in to search for it.
06-16-2014, 03:38 AM | #2 |
Re: My bed is crooked
If the wood is not in the bed then there's 3/4 of an inch right there. The wood goes between the bedside and the cross bars so if it's gone and your bedsides are sitting directly on the cross bar then the bed will be lower than stock. Some parts books also show a thick rubber pad that goes between the frame and the cross bars which would also give you some height.
Panel Beaters C.C. |
06-16-2014, 05:16 PM | #3 |
Cool thats what i needed to know thanks! Making sure i wasnt missing something.
06-16-2014, 07:02 PM | #4 |
Yep...mine does the same thing...cause the wood isn't in it...the right rear is higher then the left rear...almost thought the frame was tweaked its so bad! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-17-2014, 12:44 PM | #5 |
did the rubber pads come in all yrs 60-66? my 61 didn't have them?
1961 chevy K10 my build is------------61K10 build |
06-17-2014, 09:54 PM | #6 |
From what I've been told the rubber was not a factory-installed item. It was installed as a aftermarket add on so you didn't have a metal on metal surface.
06-17-2014, 11:27 PM | #7 |
I have thin rubber pads on one side of mine i think
