Old 08-03-2003, 06:47 PM   #1
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Cab Mounts...
Can you replace Cab mounts without removing the Cab? Like just jacking it up enough to put new mounts in? Anyone done it?
I would think my rear cab mount is shot cause I'm getting a little sag and alot of movement from it when I drive...so any suggestions would be helpfull thanks
Brian
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 08-03-2003, 07:22 PM   #2
crazy longhorn
Fabricate till you "puke"
Yes you can swap the mounts without removing the cab. when I did mine, i worked 1 side at a time....the longhorn only has 4 mounts(steel tilt clip), but the same should work for your truck. Just loosen them all up a little, so you will have a little room to jack the cab up enough to slip the mounts out/in. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-03-2003, 10:05 PM   #3
Canadian694x4
Born To Lose Club
ttt
