06-17-2014, 12:44 PM | #1 |
C10 CLUB Y QUE!
Porterbuilt and headers
What Headers are you guys running????
06-18-2014, 07:32 AM | #2 |
Re: Porterbuilt and headers
I'm still putting mine together but I have hooker 2466hkr headers and seems to be what everybody is running and it's what Porterbuilt recommends
06-18-2014, 07:43 AM | #3 |
67-72 parts collector,…
x2
06-18-2014, 07:57 AM | #4 |
C10 CLUB Y QUE!
ok thanks guys
06-18-2014, 08:09 AM | #5 |
C10 CLUB Y QUE!
called Summit the Recomend this for our truck..
http://www.summitracing.com/parts/pte-h8021 i rather have a mid size lenth |
06-18-2014, 10:03 AM | #6 |
I don't know sick5 you might want to check with Nate and Dave before ordering they now the hooker 2466 fits I'd just hate for you to order them and them not fit cause of the Porterbuilt stuff
06-18-2014, 10:16 AM | #7 |
C10 CLUB Y QUE!
True... thanks bigdock
06-18-2014, 01:06 PM | #8 |
C10 CLUB Y QUE!
other idea i had was to grab some ram horns and run the pipe like this.
i rather have the pipe run in this direction better. What do yuou guys think? |
06-18-2014, 01:58 PM | #9 |
C10 CLUB Y QUE!
And another thing is i have an LT31 from a 97 tahoe would that recomended header from Porterbuilt work on my heads
06-18-2014, 02:10 PM | #10 |
What EXACT Porterbuilt stuff are you talking about?
I used the 2466 Hooker headers with the Extreme Dropmember on a 67-72 chassis,... and it worked just fine. I assume this is on your '65?
06-18-2014, 02:39 PM | #11 |
C10 CLUB Y QUE!
Porterbuilt frontend
what im wondering if those header fit an LT Engine? and yes its a 65 the way the shorty are well end up causing issue with my brake lines i made. with the mid range it will go past the point where my brake line are and will make a better install. Keith you got any pic of your install. Last edited by Sick5; 06-18-2014 at 02:46 PM. |
06-18-2014, 03:16 PM | #12 |
06-18-2014, 03:08 PM | #13 |
C10 CLUB Y QUE!
well i founds some on craiglist.. hope they work. price is right. If not ill be buying 2466 Hooker headers next week
06-18-2014, 03:35 PM | #14 |
C10 CLUB Y QUE!
This are the hooked headers? They look like mid length headers.
06-18-2014, 03:44 PM | #15 |
Yes.
(I use Google to find these pics) http://www.summitracing.com/parts/hok-2466-1hkr I would call them a mid-length Chevelle header,...
06-18-2014, 04:30 PM | #16 |
Can you run full size plugs or like the Shorties I have, run header plugs? I also have fat MSD 90° BOOTS on the out side plugs.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
06-18-2014, 04:32 PM | #17 |
C10 CLUB Y QUE!
When I had full header I had to use shorty spark plug
