transmission and rear end
Good day all
is there a sure way to tell what transmission u have and is there away to determine the gears in rear end without removing cover . Always wondered whats in my truck. Thanx Zibs71 |
![]() Join Date: Mar 2003
Re: transmission and rear end
Lets start with some type of description of the truck in question
Sorry its a 71 chev c10 with a 350 4 bolt main
zibs71 |
ok lets pull a few more teeth...
automatic or manual? |
Automatic
zibs71 |
#6 | |
1 Aluminum Powerglide 14 bolts 2 TH200 Metric 11 bolts 3 TH350 13 bolts 4 TH400 13 bolts 5 TH200-4R 16 bolts 6 TH700-R4, 4L60, 4L60E 16 bolts 7 4L80E 17 bolts The rear axle ratio can be found by jacking the rear wheels off the ground, putting the trans in neutral and turning one wheel until the driveshaft goes through 2 revolutions. Divide the number of turns of the wheel by two...voila' the rear axle ratio. |
Thanx Fitz
I now know its a TH350 thanks for all the replies. Now to check rear axle ratio on the weekend!! Zibs71 |
