Old 06-20-2014, 04:47 PM   #1
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Dropmember with LS/4L65-E clearance issues
I have the Dropmember 3.tube, I guess now it would be called the Extreme Dropmember. I finally sat a motor and trans (5.3 / 4L65-E) in the frame and test fit the cab. With the frame rails flat on the ground I have the engine and trans tilted 5° to the rear. After cutting the floor for the high hump things still aren't clearing well. After finally getting everything trimmed so the trans clears the cab its now holding the high hump up off of the floor about 3/4". I also had to trim the floor some behind the high hump to clear the tail housing. I was just wondering if anyone else has run in to the same issue, maybe I have something assembled wrong. TIA.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-20-2014, 06:29 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Dropmember with LS/4L65-E clearance issues
Sounds about right!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 06-24-2014, 01:03 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Which year truck and can you post some pics of the clearances, including the rack to pan clearance?
Thanks!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
