Vintage Evil
20x15 wheel
Can a 20x15 wheel fit under a coil spring truck with simply a tub? or is other modification needed? the rear is dropped 6in with a drop coil. I plan on ordering a custom offset so I should be able to get the wheel centered where I want it... just concerned about it rubbing on the coil or bump stop bracket... if I go 20x15 wheel I would be wrapping it in the M/T Sportsman S/R, LT 29 x 18R20. Height is dead on what I am looking for.
Thanks in advance...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
Re: 20x15 wheel
You should be Ok with the 15" wheels with just the sheet metal work, and no frame mods. It will come close, but will have enough clearance. Here you can see a 14" wide wheel with a PB onboard bag setup, and it would barely have room if there was a coil spring sticking outside the frame some in front. You would have to move the wheel as far outside as possible.
Measuring is always best when trying to squeeze the maximum in there. Do they offer a narrower tire than an 18" wide? Maybe a 16"? ![]() ![]() |
#3 | |
![]() Join Date: Apr 2005
Re: 20x15 wheel
What size and brand are the rear tires?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Apr 2010
Re: 20x15 wheel
I can't swear rob, but they look like 405/25/24's. definitely Pirelli tire tread
Wade |
Re: 20x15 wheel
It has to be that 405/25/24.... I agree.
Vintage Evil
Re: 20x15 wheel
Yeah loving those rear tires... would hate to see the price tag... Pirelli doesn't appear to be making them anymore or they are just starting... cant really find any to buy except Ebay and Pirelli doesn't list on their site...
as far as M/T they offer: Tire: 29X15.00R20LT Rim width: 13.0-14.0 Tire: 29X18.00R20LT Rim width: 15.0-16.0 They do have the 15in wide tire but then it drops down to a 13-14 rim width which I am having trouble locating... Intro, Billet spec, etc tends to jump from 12-15 with nothing in between...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax Last edited by chevyguy_72; 06-25-2014 at 08:44 AM. |
Re: 20x15 wheel
As far as Pirelli not making them, been hearing that for last few years. I think there are way too many people running those for them to stop. What I have heard is they make a "run" of them for the year at a certain time and supply gets low before the next run. Maybe give them a call to confirm that if your seriously considering them, that's what I did 2 years ago.
Wade |
#8 | |
Re: 20x15 wheel
#9 | |
Re: 20x15 wheel
The tires are available and can get them for you. I have gotten them in the past for customers. I have heard the same thing about not being available, but never had an issue getting them so far. Pricing for tires changes constantly, and last time I checked, they were $470 a piece. |
#10 | ||
Vintage Evil
Re: 20x15 wheel
As far as custom widths from intro etc what kind of money does it add to have them make a 13/14 inch wheel... I am a little concerned over this process as on the Camaro forum there were companies doing custom width wheels that were not cheap and they were having horrible balancing etc issues with them... then the company wouldnt stand behind them so guys were stuck with $5k worth of paperweights (Not saying that would be the case here... just explaining weariness)
Re: 20x15 wheel
I've got a 14" wide Raceline and no issues balancing. My set of 24X9 & 24X14 were about $3300-$3400 delivered, if I remember correctly. About a grand less than intros (and I've had them too, & loved them)
Wade |
Re: 20x15 wheel
With tires?
Vintage Evil
Re: 20x15 wheel
which racelines do you have? more pics somewhere?
and wondering the same as rob... which tires and sizes you running? Pirellis we discussed further up the thread?
meowMEOWmeowMEOW
Re: 20x15 wheel
With the exception of brake clearance, you all are making me glad I only run a 15" rim. I really like only paying $150/e for MTs on my 15x12's
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#15 |
Re: 20x15 wheel
Yeah, they are a little more than that. What size tire you running on that 15x12?
Wade |
#16 |
meowMEOWmeowMEOW
Re: 20x15 wheel
325/50/15 MT DOT. Could actually go a little bigger. Stock width 12 bolt, custom beadlocks.
#17 |
Re: 20x15 wheel
Found the gmc on Craigslist. Sometimes good stuff pops up. Original 307/turbo 400, posi trac.
Post some pics of the 325/50/15 I'd love to see how they look on your truck Wade |
#18 |
Re: 20x15 wheel
Yeah man! Wade better keep that one a driver for a little bit. I picked up a 68 a few weeks ago my self
#19 | |
meowMEOWmeowMEOW
Re: 20x15 wheel
#20 |
Re: 20x15 wheel
These are 24x15 as well and fit without doing anything to the suspension. Although I do have the ride tech strong arms kit.
Rear was shortened and I had to flip the calipers around because they hit the trailing arm. I just ordered a set of matching 20x15's. Haven't decided on the 31'' or 33'' M/t's yet
1967 C10 SWB 6.8L/4L80 |
#21 |
Re: 20x15 wheel
oops
#22 |
Re: 20x15 wheel
Beautiful wheel, and truck!!
#23 |
Vintage Evil
Re: 20x15 wheel
#24 |
Re: 20x15 wheel
