Old 06-25-2014, 05:12 AM   #1
donthekawguy
donthekawguy's Avatar
brake rotor ?
I'm coming over from the 60-66 truck side with a question. I got some CPP 2 inch drop spindles from Summit. They called for using the 1.25 inch thick rotors. I got the rotors and calipers and I'm trying to put them on my truck. The rotors fit fine but I'm having trouble with the calipers. I might have been sent the wrong spindles. What trucks had the 1 inch thick rotors and what trucks had the 1.25 inch thick rotors?
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-25-2014, 06:35 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: brake rotor ?
No rhyme or reason on the truck year.
I've seen a lot of different engine combos and option packages for these brakes. 1" rotors didn't happen until 81-87,... But you could also still get the 1.25" rotors found in the 73-80 trucks.
Keith
Convert to disc brakes.
Old 06-25-2014, 07:52 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: brake rotor ?
Here is the brake system release chart for '87, which shows the rotor usages. 1" rotors are on the super light duty C10's, like manual brakes or the 5600 lb GVW JB3 power brake system.
Fortunately (or unfortunately, depending on your perspective) we did not build many of those.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-25-2014, 11:33 AM   #4
1977cheyenne_C10
1977cheyenne_C10's Avatar
Re: brake rotor ?
My 77 Gmc heavy half has 1.25 rotors
1977cheyenne_C10 is offline   Reply With Quote
Old 06-25-2014, 11:51 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Re: brake rotor ?
My 84 GMC and my Son's 86 Chevy, both have the 1.25 rotors.
Frank
Old 06-25-2014, 12:01 PM   #6
1977cheyenne_C10
Re: brake rotor ?
Keith is there a reason why General Motors put two different rotor size?
Old 06-25-2014, 12:02 PM   #7
Keith Seymore
Re: brake rotor ?
To save piece cost.
With trucks they are always trying to have a "value leader", so they can advertise the cheapest MSRP. Cutting corners every little bit helps.
K
1979-1986
1986 - 2019
Old 06-25-2014, 05:15 PM   #8
MalibuSSwagon
Re: brake rotor ?
I just swapped over to 1.25 rotors on my C10 (along with the drop spindles) the cross reference on calipers for my truck went back to 1979. Looking on Rockauto for calipers and rotors, it is very confusing when trying to pick out the correct big rotors and calipers for a 81+ C10.
So, when I went to my local O'Reillys, because shipping is insane on these heavy pieces, I asked for rotors and calipers for a 1979 C10, since 1.25 was the only option that year, the parts jockey can't screw it up. The brake lines will bolt up.
Yes, there are different calipers for each size rotors, the 1.25 calipers are .25 inches wider than the 1.00 calipers. Weird right? haha. You'll know if you have the wrong calipers because you'll load up the brake pads and they won't fit over the rotor.
MalibuSSwagon is offline   Reply With Quote
