06-25-2014, 01:14 PM | #1 |
What Borgeson U-Joint on 72 Blazer Column?
I am getting parts for a guy with a 72 Blazer and he just did a crossover steering setup and now he wants to ditch the factory Rag joint-steering shaft setup. It looks to be 3/4" 36 on the steering box but I don't have the truck to measure what's up on the column end. Does anyone know? It looks to be the same as the lower by a pic.
Any help is appreciated. |
06-25-2014, 01:15 PM | #2 |
Re: What Borgeson U-Joint on 72 Blazer Column?
Borgeson didn't know.
06-26-2014, 01:41 AM | #3 |
Isn't the flange welded to the double D shaft of the column? I think they make a fitting for the double D.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
06-26-2014, 07:24 AM | #4 |
Yeah, the flange is part of the shaft. i think they are replacing that though. hopefully with a collapsible DD. the box is a 3/4"x36spl. i don't think the end of the column is actually splined. it is clamped and the clamp bolt also locks into a notch. you may have to weld the joint on if they dont offer a clamp on style.
i have been planning this for mine, but i am not anywhere close so i havent sorted out the details. |
06-26-2014, 08:50 AM | #5 |
Currently Blazerless
You could just do what I do and use a steering shaft from a 84 to 96 Jeep Cherokee, it's pretty much a bolt in and the Jeep shaft has a built in vibration dampener. You will have to collapse the shaft a little and on the column end you will have to grind a small notch to clear the different location of the pinch bolt. I pick them up for about 25 bucks fom the salvage yards, I have a 200 dollar Borgenson shaft that I used in my old 1 ton and believe me the Jeep shaft is just as good.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-26-2014, 08:51 AM | #6 |
Sorry I can only post 1 pic at a time on this Ipad.
06-26-2014, 08:52 AM | #7 |
Last one
03-18-2016, 03:02 PM | #8 | |
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
03-18-2016, 05:59 PM | #9 |
03-18-2016, 08:07 PM | #10 | |
Looks like those are all for 73+... are there any write-ups or videos for 67 through 72?
