06-26-2014, 08:25 PM | #1 |
2001 s10 no power at all
Ok guys I'm having trouble diagnosing my electrical problem so first I'll tell you what I've done and checked.
What I have - 2001 ext cab s10 with 5 speed manual and 2.2l engine What I've done: The truck was run hot and the head was warped so I got the head machined and new head gasket, new ignition coils, timing set (since I was there and has 200k), and any gasket in the head gasket process. The only thing I have not hooked up are the spark plug wires to the spark plugs as I was wanting to prime the oil up to the head before fully starting. I checked the battery it was dead so I got a new one and when I turn the ignition I get no power to anything - no dome light no ding ding nothing. I don't even hear anything to the starter. I believe I should rule out the battery and clutch safety switch as the car would still give me radio and lights even if the safety switch was bad correct? I also took a multimeter and checked volts on use starter with key in start position - red on terminal and black on ground...nothing but switched to continuity and I was getting continuity through the same setup. I am stumped....any help would be great!!! |
06-28-2014, 11:36 PM | #2 |
Re: 2001 s10 no power at all
Found no power to fuse box and replaced main fuse under battery. Now have power to fuse panel but no power to fuses. Anybody?
