Old 06-27-2014, 10:15 PM   #1
jec
jec's Avatar
Heater Hose Tube on Radiator
Getting ready to install new heater hoses on my Longhorn 402 big-block. Truck has no A/C correct factory heater box on firewall with 3/4" core tube on top and 5/8" core tube on bottom.
I have the normal 5/8" fitting on top of engine manifold near thermostat housing. This supplies hot water into the bottom of heater core.
I have the normal 3/4" fitting for a return from the top of the heater core to the side of the water pump.
Any ideas why my radiator has 3/4" Male Heater Hose Tube about an inch below filler neck pointing straight out toward engine?
Maybe it's for an auxiliary heater return or something?? I can't think of any purpose for it. Maybe somebody knows or has seen it on other trucks.
jec is offline   Reply With Quote
Old 06-28-2014, 01:58 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Heater Hose Tube on Radiator
IIRC, the preferred routing for the 3/4" return hose is to the port on the radiator -- not to the water pump.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-28-2014, 02:01 AM   #3
7dee2
7dee2's Avatar
Take a look at this thread http://67-72chevytrucks.com/vboard/s...d.php?t=188679
Here is another pic from the 1972 Chevrolet Truck Chassis Service Manual 10 to 30 (1A-3). I have the same HD Rad in one of my C30's it's non-A/C with Turbo 400. Hope that helps.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 06-28-2014, 09:04 AM   #4
jec
jec's Avatar
O.K., thanks alot.
Found the pictures in my Factory Service Manual Section 1A.
I'm going with the 3/4" return to the radiator.
Old 06-28-2014, 09:51 AM   #5
7dee2
7dee2's Avatar
No problem, I have not had any issues running my truck this way.
Brett
Old 06-28-2014, 10:09 AM   #6
FirstOwner69
FirstOwner69's Avatar
Just to clarify the hose routing...
Based on my observations, the earlier model year trucks had the 5/8" hose from the heater core to the intake and the 3/4" hose to the side of the water pump. There was no 3/4" fitting on the radiator. I'm not sure when the change actually occurred. My 69 with a 350, A/C and 4 row radiator is routed this way. All, or most, of the later year trucks (71/72?) I've seen had the 3/4" hose to the radiator.
FirstOwner69 is offline   Reply With Quote
Old 06-28-2014, 03:48 PM   #7
davepl
davepl's Avatar
I've been working on GM cars and trucks for along time and I've NEVER seen a heater hose go directly to the radiator. I almost looked to see if it was April 1.
You learn something every day. Why only with automatic trans?
It looks like hot water comes out of the engine, goes to the heater core, and dumps back into the radiator. I would think this would really slow down engine warmup...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-28-2014, 03:55 PM   #8
LSUMurse
LSUMurse's Avatar
Wouldn't it only slow down warm up if you had the heater on? If the heater is not actively pulling heat from the core, there would be only a slight amount of heat escape from the hoses, etc. OOOOOORRRR, I could be completely wrong. Which, tends to happen more so than the other option.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 06-28-2014, 06:21 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
All I know is I bought my '72 K20 (with factory A/C) when it was just 5 years old and by all appearances, it was 100% original at the time. The heater return hose went to the radiator. Still does, though the radiator has been replaced once (and the heater hose more than once).
- Mike -
RIP El Jay
Old 06-29-2014, 10:45 AM   #10
kaycee
kaycee's Avatar
OK got a ? for you all ,it seems to me that it would cool down the system better if it went to the radiator.Is there any logic to this ,I have a/c cab(someday I'll hook it all up) but man does it get heat from the heater core.Even when I just try and get outside vent air
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 06-29-2014, 03:56 PM   #11
Andy4639
Old member
Andy4639's Avatar
Question Re: Heater Hose Tube on Radiator
Here is the heater hoses in the factory manual for AC.
I agree if the hose on the water pump pumps water through the heater core and dumps straight back to the radiator it would take longer to heat up the truck to correct temp. The hot engine water going through the heater want cool it down much and dumping back straight to the radiator will not let the engine water temp get hot very quickly because it's cooling off with out building heat up in the system.
How long does it take for the truck heater to warm up the truck on cold days? That would be the test to perform and see if there is enough differance in the heat to change it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-31-2014, 03:15 PM   #12
Legolas894
Chemist under the hood...
Legolas894's Avatar
This is the same issue I'm having so instead of posting another thread, I'll just add on. I had the 3/4" line on the rad capped with a rubber end cap and hose clamp. My setup was 5/8" line from intake to bottom of heater core, 3/4" line from top of heater core to fitting on water pump.
Yesterday, my rubber rad cap failed, spewing coolant in the parking lot so I started to look to see if I could fix this setup. What do people think about capping off the water pump inlet and letting the heater core go to the rad fitting? The 3/4" hose fitting on the water pump doesn't look like it will come off easy so putting the plug on it may mean taking the water pump off.
Is there any advantage having the heater return to the rad instead of the pump?
I have a 283 with no A/C and manual trans.
Thanks!
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 08-31-2014, 04:59 PM   #13
Fitz
Unless you live in a place that can get really hot in the summer you can not appreciate the wisdom of routing your heater this way. When you are pulling a load up a steep grade on a 115 degree day in the desert and the engine temp is climbing fast you will appreciate that heater return to the rad. Turning your heater on when it's really hot outside might not seem to be a good idea but if it prevents a boilover 100 miles from the nearest water you will be glad that the engineers at the General did it this way.
Fitz is offline   Reply With Quote
Old 06-28-2014, 05:31 PM   #14
davepl
davepl's Avatar
I wasn't thinking of heat loss through the heater core as much as the fact that it would be continually cycling its warm coolant through the core and back out to the rad rather than keeping it in the engine. So I see it as not having a thermostat but with a smaller rad hose, in a way.
A "normal" configuration would send it through the heater core and back to the engine for further warming (or re-warming). Once the thermostat is open and all the coolant is at operating temp, shouldn't make a diff.
Old 08-31-2014, 04:28 PM   #15
davepl
davepl's Avatar
The LMC rad I bought for my '70 had this port. The factory one didn't so its another case of a 'halfway universal' reproduction part.
Mine leaked badly. I wound up having to pull the rad out, put a metal plug in, and solder it up.
