Old 06-28-2014, 06:03 PM   #1
RPBurris
RPBurris's Avatar
HD lighting harness question
I bought one of the HD headlight harnesses a year ago or so from VH Coachworks and am just now getting around to installing it. I have an email into him but see from his sales thread there may be some issues there. Anyway, my question is whether or not the drivers side original headlight connector can simply be cut off and splice the tan and green (i think those are the colors) together so they run to the passenger side. That way i can eliminate the drivers side original plug and tidy up the wiring a little bit. It is a very high quality harness and it will be great when done. Thanks for your guys' (and even gals) help.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 06-29-2014, 02:18 PM   #2
RPBurris
RPBurris's Avatar
Re: HD lighting harness question
Buehller?
Old 06-29-2014, 03:44 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: HD lighting harness question
It would help to know what wires are what on the harness. As long as you tap into the High beam and low beam it shouldn't matter if you cut the old light connectors off if not going to use them with the new lights.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
