The headlights on my 1958 apache start to pulsate at night, a few seconds after the truck starts running. The truck does have an alternator on it. Could it not be putting out enough current? The original gauge reads just below the center dot. When the lights pulsate all of them do it including the dash lights.
Re: Pulsating lights? What would cause this?
It sounds like the cut out relay in the regulator is cutting in and out.
Is this just at an idle or while driving down the road at say 45 or 50 mph? Generators are cute and "original" and sometimes it's desirable to run one so everything looks correct but the downfall is that they don't charge worth squat at and idle. On cruise nights you can tell the guys with generators because the lights go dim when they are at an idle and get brighter as the vehicle speeds up and the generator comes up to full charging ability. I haven't had a generator on anything I've owned since 1973 when I traded my 59 ElCamino off but one project I have will get one because it would be all wrong looking with an alternator. If i.t goes over 100 miles from the house it will most likely be on a trailer behind the 48 or my 71 as it isn't a distance driver by any stretch of the imagination
#3 | |
Boy howdy, I need to clean my glasses. I was sure that said that it does not have an alternator.
Have you taken the alternator into an automotive electrical shop and had it properly tested? It may have a bad diode or a bad connection in it. A bit of an explanation on how the diodes convert AC current to DC current and also somewhat of a clue to your problem with the pulsating current. http://alternatorparts.com/understan...ternators.html
Aliens are coming after you...
anybody else ever have this problem? have any advice? what if my alternator tested fine?
Did this happen with a previous alternator or generator? I would have the alternator checked but also check the mounting of the alternator. If its not tight you may have a bad ground.
![]() Join Date: May 2007
you need either more load or more battery, the pulsating is the rectifier switching and making DC output. Headlights are a high current draw, and the alternator is an AC generator, the battery is intended to "stiffen" the output. Do you have your headlight relays wired straight to the alternator? If so, wire them to the battery, it should improve your pulsating.
pulsating? as in turn off and on?
if they are actually turning on and off rapidly then the problem is your headlight switch the stock 55-59 wiring harness had 3 or 4 fuses in the whole system, none for the lights, the switch hooks directly to the battery looking at this picture of the headlight switch, the batt connection has a U-shaped bar off that U-bar are 2 sets of ''points'' these are bi-metal overloads, when power goes thru the metal strips they heat up like a thermostat too much power or as they wear out the over current causes the points to break turning the lights off once the points break the strip cools down the lights turn back on and the cycle gets repeated it is set up this way to protect your wiring, but also keep your lights on in case your approaching a curve as they overload if you have stock headlights and wiring you can tweak the strip just a bit to be a little less sensitive this is your only wiring protection, if you over tweak you can burn up your harness if you have a new wiring harness it should have a breaker on the headlights, you can bend the strip so it never opens the points ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
no the lights are not flashing on and off. they're pulsating, brighter and dimmer slightly, at a somewhat rapid pace.
then store my post in your noggin for future reference
![]() how big is your alternator and what loads do you have? electric fan, ac, halogen lights?
charging system checked out okay, 14.25 volts with no load, 14.57 volts under a load. 12 volts cranking.
no electric fan, radio doesnt work. i dont believe the truck has halogen headlights. |
Early alternators had an external regulator while later ones had an internal regulator (three wire) or one wire. Which style do you have?
3 wire i believe, one snap in plug and a plug that has a rubber boot over it both run towards the firewall.
![]() ![]() grounds ![]() |
#15 |
quick search on the internet, because I do not know why, shows it is probably the alternator diode, or battery going fubar or overloaded. You have eliminated #2 so I'd spend $30 on a new 63amp alternator and see what happens. I thought everyone was like me and had a couple just laying around??
#16 | |
Alternators are cheap. Just replace it.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#17 |
I think I'll try that and see if that fixes it, its only had 13k miles put on the truck since 1996. I did notice the AMP gauge at idle in gear tends to drop as the lights surge, and when your driving down the road the lights pulsate more rapidly than at an idle. can an alternator test that its charging good, but be bad?
also here's a picture of the gauge when no lights are on at an idle in park. you can see that its just a hair below the center dot without the lights on. ![]() and here's the gauge after the lights are on, in gear. I would think its a bit low wouldn't you say? ![]() Last edited by yellow400ex05; 06-30-2014 at 01:05 AM. |
#18 |
I would start by readdressing that ground connection. I hope that's not the only one. You need a 2 gauge or better from the engine to frame and at least 8 gauge from engine to body. The one shown looks to be the right size but the wire at the ring splice looks weak.
Good luck, Rob
My '47 C.O.E build |
#19 | |
#20 |
Just mentioning that I am real happy with the 94-amp alt I bought for $75 at O'Reilly's.
http://www.oreillyauto.com/site/c/de...eyword=01-1015
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
#21 |
When alternator output is greater than electrical system requirements the regulator will switch on and off. This is normal. Quality regulators have a tight window between on and off voltage so the switch isn't visible. Inexpensive aftermarket alternators often use cheaply made voltage regulators and can vary 2-3 volts between kick in and kick out voltage. If the alternator is charging and the diode pattern is fine, it's probably the regulator working within it's normal parameters.
There are some things that you can check. If the regulator is sensing system voltage at the alternator rather than the battery then you need to ensure the power and ground cables are large enough and in good shape. High resistance will cause the voltage at the alternator to be higher than the rest of the system and the regulator won't get an accurate picture of the state of charge. You can also ensure the sense wire (if equipped) is routed to the battery. But it really sounds like a cheap regulator is at the heart of the issue imo. Last edited by 1project2many; 07-01-2014 at 11:23 AM. |
