suspension idea
well i just got a 70 C10swb truck as a new project. my last one was a 96 z28 camaro lt1 6speed. i did lots of work to her but the body and interior were pretty much shot (money went to motor and suspension parts). so instead of getting rid of all the good parts i was thinking of doing a custom rear suspension on the truck. and put a camaro torque arm suspension on it. got all brand new parts to start with including coilover shocks. just wondering what you guys think of this idea. i think it should work pretty good and ride nice with the stuff i have and sorta be one of a kind. the truck right now has leafs a 327 and th350. going to have torque arm suspension 383LT1 and t56. also 12 bolt moser with 4.10 gears.
Jared 2014 Ram 2500 powerwagon 2006 GSXR 600 2012 Arcticcat proclimb 800 1970 C10 SWB 5.3LS turbo and 4L60E ![]() ![]() "all throttle no bottle" "Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences" "its not turbo lag, its for play" |
Re: suspension idea
From what I know of the torque arm suspension is that you will either have to lengthen the torque arm to match the wheel base or shorten the wheel base to match the torque arm.
The pivot of the torque arm is supposed to match the pivot of your U-joint off the transmission. You probably could use a 2 piece shaft to easily give you the extra length you need. It is a good set-up, but has swap limitations. |
#3 | |
Re: suspension idea
I'm just glad to be here!
Re: suspension idea
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=589967 TCI is developing a torque arm rear suspension for these trucks....
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Re: suspension idea
Take a look at http://www.jakesrodshop.com/Products.html he has a weld in torque arm kit for the 1st and 2nd gen f body.With some fab and tweaking it could work for you.
#6 | |
Re: suspension idea
