Old 08-04-2003, 09:25 PM   #1
71sub
71sub's Avatar
Engine problems -- slight backfire ...
I've got a mid-80's 350, Edelbrock Performer intake and HEI with 700r4.
Installed new Edelbrock 650cfm vacuum 2nd's and new spark plugs gapped @ .045's.
While idled @ ~ 700 RPM, no problems -- but once I put into gear, I get backfire sputers on the passenger side AND I have no
power out of engine --- used 2x the amount of gas today going to work !!!!
VERY frustrated. I've followed Edelbrock carb tuning tips
--- back out 2 full turns, turn in clockwise ( one side at a time ) till RPM drops and put back a 1/8 turn. BTW: timing's at 8 degrees.
What am I doing wrong --- what else do I need to check ?
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 08-04-2003, 09:58 PM   #2
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Sounds like you might need to advance the timing a bit more. My 350s running at 13-14 degrees advance. I could b e wrong though.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 08-04-2003, 10:11 PM   #3
Class of 69
Class of 69's Avatar
If the carb was only thing changed before the problem developed, I would look for a vacuum leak. Strongly suggest rechecking the plug wire location. Sounds like you may have crossed two.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-05-2003, 12:18 AM   #4
71sub
71sub's Avatar
vacuum advance
Well --- I removed the carb and blew air through the port vacuum inlet and installed a 1/2 riser.
Power has been restored to engine -- but still backfires on the passenger side, not at idle anymore, but during acceleration.
Does that mean I too rich or too lean ?
Thanks for all the guidance !
Old 08-05-2003, 12:22 AM   #5
jcueckert13
jcueckert13's Avatar
i think that means it is to rich but why is it only happening on one side
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 08-05-2003, 08:43 AM   #6
smokekiki
Mike
smokekiki's Avatar
Check to make sure Your plug wires are in the right order and there is no crossfire.I would advance the timing a little.Mine with hei runs best at 12 btdc
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-05-2003, 10:24 PM   #7
tripp
make sure you check the firing order and timing. i had the same thing happen to me and it caught my carb on fire!
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 08-05-2003, 10:32 PM   #8
lngbed71
Nothing fits but the oil
lngbed71's Avatar
My guess is vaccum leak, check the manifold "T" fitting directly behind the carb, on the manifold. Sometimes if this is off it pulls additional air right into the right side causing backfires and sputters as you describe. You may also want to check the vaccum port on the rear of the carb itself to see if there needs anything connected or plugged off.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
