Old 08-04-2003, 11:22 PM   #1
71sub
71sub's Avatar
Edelbrock vacuum advance port
Question on a 1406 --- 600cfm carb.
On two front vacumm ports --- the one on the drivers side has good suction BUT the one on the passenger side has nothing.
The one with nothing is the vacuum line I have connected to the HEI distributor. Is the the carb supposed to show suction or the distributor ?
If it's the carb, and it shows nothing -- how do I fix that ?
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 08-04-2003, 11:43 PM   #2
crazy longhorn
Fabricate till you "puke"
the pass side is ported vacumn, & wont show on a vac guage till the throttle is opened slightly......it also drops under full throttle, like the manifold vac fitting on the dr side. Your HEI was setup to run ported vacumn, & if you are running stock or very mild you may want to leave it that way. If you do a "recurve" & adjustable vac can on the dist, i would hook the dist to manifold vacumn. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-04-2003, 11:56 PM   #3
71sub
71sub's Avatar
Thanks Loco !
So, at idle I will not feel the ported vacuum inlet suck my finger, under under acceleration yes AND at WOT it'll fall down some ?
Old 08-05-2003, 12:08 AM   #4
crazy longhorn
Yup, @ WOT it should drop completly off(under a load)
