Parking brake components
I recently bought a 66 C10 SWB that I'm in the process of putting back together. The PO appears to have remove almost all of the parking brake parts. All that remains is the 2 rear cables hanging out of the drums (zip-tied to the frame) and the lever under the dash. I don't see any remaining brackets or hardware so I'm starting from scratch.
Does anyone have a list of all the parts I need and if any vendor sells all of them still? A parts manual is next on my list but I was hoping to get an accurate list so I can just buy everything I need all at once. Current truck specs: 1966 C10 fleetside shortbed, th350 auto, 6 lug rear drums. Unknown what is original and what is borrowed since the front clip suspected to be from a mid-70's truck (5-lug disc) and the trans cross member looks to be changed (different shade of dirt).
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Parking brake components
Here is a detailed pic of pieces.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=97 But compare the prices from other vendors. LMC tends to be overpriced on many things.
be careful, the brake cables for a coil spring axle are different than a leaf spring axle. there is a company named " inline tube" that makes reproduction cables for both leaf and coil spring axles. www.inlinetube.com give them a ring. very nice people. they sell most of their cables on ebay. they also make pre-bent brake lines if you need them
Moderator
![]() Join Date: Dec 2012
Too funny. My truck has all the parts except for the parts you actually have...
Thanks this is what I was looking for! The previous owner did all new brake lines but left off the e-brake parts.
