07-05-2014, 10:17 PM | #1 |
Help hooking up speakers
Every radio I've hooked up before has 2 wires per speaker. A color for each then same color and a stripe. I bought a blazer and it has 4 6x9's and 2 speakers in the door that all cut in and out at will. I looked at the wiring today and off the radio is this
1 red 1 red/white stripe 1 yellow 1 black Those I know. The speaker outputs however are only 4 solid colored wires. Green,purple, grey, white. How do I hook up the speakers to that? Do they share a common ground? I will eventually replace it all but I need to do a lot of other stuff to the blazer first. Thanks in advance for any info. |
07-05-2014, 10:36 PM | #2 |
Re: Help hooking up speakers
what brand of radio
07-05-2014, 10:42 PM | #3 |
07-20-2014, 04:57 PM | #4 |
Old member
I would say they share the common ground.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-20-2014, 08:33 PM | #5 |
many older radios had common grounds where the neg was hooked same as body ground
possible red 12v+, black 12v- and left, right speaker, common ground imo the head unit is junk, you will get better sound out a $69 pyle head unit
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-21-2014, 07:54 AM | #6 |
Old member
I agree you can buy pretty good radio's now for under $100.00 and they will sound a lot better.
