flywheel clutch question. help please!
i have a 1967 c10 witha inline 6 witha 3spd and its seen its day.
buring oil and i know what that means, i have an original 1965 283 v8 with about 60,000 miles on it. will the 283 bolt right up to my manual 3spd on the colum?? thank yall |
Re: flywheel clutch question. help please!
Yes. It will bolt up to the 6 cyl. bell housing.
all the six cyl parts like the starter flywheel clutch & bellhousing will fit a v8. I installed a 350 in a 67 GMC and the 6 cyl side mounts fit the V8 the only change I did was install a larger radiator the had three rows of cores. Unless you some how move the rear engine mounts & crossmember the V8 engine wont set any farther back than the six cyl does. on my 67 GMC and every 60 thru 66 standard shift truck ive ever seen there are two bolts that go through the rear mounts and thread into ears on each side of the bellhousing. and the rear crossmember is riveted into place.
so i should be fine with the flywheel and clutch bolting up strait to the 3 spd tranny? thanks such a big help
let me be more detailed, sorry 283 bolt right up to the 3 spd |
![]() Join Date: Apr 2007
yes, your clutch pressure plate ,flywheel , bell housing and 3 speed from your 6 cylinder will bolt to your 283.
CAN'T FIX NOTHIN
yep it will bolt right up ! That's the great thing about 1955 thru 1974 chevy stuff everything will fit ,m love those years !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
