steering play
have a 48 gmc 1/2 ton, 6cyl. took truck out for first time, and seem to have a bit of play in my steering, I would say maybe moving wheel 4 inches before you see it starts to turn, not sure what it would be, need suggestions, thanks pete,
Never Ending Projects
Re: steering play
Assuming your front end parts (tie rod ends, wheel bearings, king pins, etc.) are in good shape, there is an adjustment on most steering boxes to help take up some play. If your box is not completely worn out, you might be able to get some of the play out there.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: steering play
I am not a mechanic, so were is this adjustment located, and how do I do it...
Re: steering play
Careful adjusting the boxes as you can mess them up if you tighten them down to hard. I would look for loose parts first, then worn parts, cracked frame mounts, etc.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
