Old 07-07-2014, 12:05 PM   #1
bonnieclyde100
overload helper springs
1 purchased a set of used helper springs the ones for the coil springs with trailing arms but did not get the plates that come off the trailing arms that they come in contact with. my question is do the helpers hang above the trailing arms and only contact with loads in the bed or are the springs preloaded at all times? also if they hang above what is the distance from the spring to the plate. my truck is lowered a bit and i will have to make my own plates.
bonnieclyde100 is offline   Reply With Quote
Old 07-07-2014, 12:34 PM   #2
Shakerattlenroll
Re: overload helper springs
They hang above , I just wrecked my old 1970 that has them.
cant tell you by how much.
But they only contact while loaded down
Shakerattlenroll is offline   Reply With Quote
Old 07-07-2014, 12:51 PM   #3
bonnieclyde100
thank you hope someone else will chime in with the distance but if not i will guess.
Old 07-07-2014, 12:54 PM   #4
Shakerattlenroll
If she still had a rear end under her I could messure.
but its all laying on the dirt arms are twisted a bit , so it would be inacurate.
I can snap some pics when I get home though if it helps
Old 07-07-2014, 01:54 PM   #5
bonnieclyde100
doesnt sound like it would and i hate to hear that happened to you. i am thinking of making my plates removable and maybe preload the spring when ever i am going to be loading it down so i know the ride wont get stiff when ever the road dips.
Old 07-07-2014, 02:05 PM   #6
Shakerattlenroll
Its all good , this was my first truck.
been in the family since 71.
She has had enough...rusted beyond the beyond.
but fired rite up and idled for me after sitting 15 years.
she giving up the driveline to a 63 shortbox stepside..she lives on...
Old 04-21-2017, 11:29 PM   #7
thetruckrman
Hey bonnieclyde100, did you ever make your own helper spring plates? I need a pair and wonder if you were able to make them work.
thetruckrman is offline   Reply With Quote
Old 04-22-2017, 09:39 PM   #8
bonnieclyde100
no I still have not gotten around to making them.
Old 04-22-2017, 09:42 PM   #9
bonnieclyde100
when I do make them I need to mount them under the trailing arms and not on top because my truck is lower than stock and the helpers would be touching without anything being loaded in the bed
