Old 07-08-2014, 02:58 PM   #1
N.T.Q
Advanced-Design Engineering swap kit
Was wondering if any one has any photos from there swap I bought motor mounts from them and they sit the motor back 4 Inch's from the stock location on a s10, but my fuel pump hits on the passenger side mount just wondering if I'm going to have run a electric pump or is some thing else jacked up that I'm missing
N.T.Q is offline   Reply With Quote
Old 07-08-2014, 11:02 PM   #2
Atommik
Atommik's Avatar
Re: Advanced-Design Engineering swap kit
I had the same basic problem. I made my own "swap kit" and used factory motor mounts welded farther back on the frame rails to position the engine where I wanted it. The mechanical fuel pump hit the frame, so I capped it and installed an electric pump in line just in front of the gas tank. Worked out well for me.
Atommik is offline   Reply With Quote
Old 07-08-2014, 11:29 PM   #3
Kodiaks53
I'm using the AD kit and their motor mounts and had the same problem. So off with the mechanical pump and got a electric one from Summit, problem solved.
Kodiak's 53S10 Build
Kodiaks53 is offline   Reply With Quote
Old 07-09-2014, 12:01 AM   #4
Dustint
From what I've seen as others have said your easiest option is probably to just go electric. Other option would include some fab on your own mount/clearance the fuel pump.
If you do go electric make sure to mount it closer to the tank as opposed to in the engine bay/etc. to ensure proper fuel flow.
Dustint is offline   Reply With Quote
