What's wrong with my TH350 tranny?
Trying to troubleshoot my son's TH350 AT in his '71 C10.
Yesterday it began sticking in gear (2nd gear I believe). After moving column shift to D, it's not shifting up or down and making a soft whirring or whining noise on acceleration. I replaced and checked the vacuum line and verified the vacuum accumulator is getting and holding a vacuum. Also checked AT fluid level and its cherry red and full. Kickdown cable is not stuck or binding. I visually inspected the shift linkage and it appears to move through the motions correctly and Park, reverse, & neutral all are working fine. My next guess is looking at the governor but that's above my comfort & knowledge level. Any tips? Anything else I can check prior to hauling it down to the tranny shop? Thanks in advance!
"Life is too short to use cheap zip ties" 64 C10 SWB 71 C10 LWB 72 C10 LWB |
Re: What's wrong with my TH350 tranny?
I'd check to make sure the filter isn't clogged in the pan for starters.
Pull the dipstick and smell the fluid. If it smells like burnt toast then it's rebuild time.
Fluid should be pink not cherry red. |
"soft whirring noise" sounds like a sun shell problem
