07-17-2014, 02:56 PM | #1 |
Help with ltft at 25.0
I have a 53 with a 5.3/4l60. Anything over idle I get ltft of 25.0. Engine transmission computer fuel pump all from 2003 avalanche that I drove with no codes. I have 700 miles on the conversion and get 0171&o174 codes every time I drive it. No vacuum or exhaust leaks. New fuel pump new tank new filter new 6an fuel line new fuel pressure regulator with no change. Fuel pressure is 50lbs with old and new parts. All fp regulators I have found foe this 2003 avalanche advertise 50lbs. I tried one for a 2002 suburban that was 58lbs but it would not fit. I also have a 1999 Z71 5.3 and a 2004 Z71 both hold 50lbs fp with no codes. I have no idea what to do next. Go POSTAL ????
07-17-2014, 09:23 PM | #2 |
Re: Help with ltft at 25.0
What did you do with the Evap line from the gas tank going into the intake?
o2 sensors in factory locations? Check for leaks on intake tubing? Any leaks between the MAF and throttle body will cause this. Do you have all the PCV lines hooked properly up as well? |
07-18-2014, 01:56 AM | #3 |
What filter and intake tube are you using? I used a spectra cold air intake and had the same issue.
I disconnected my MAF and the ltft went to normal. +/-3
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
07-18-2014, 02:56 AM | #4 |
meowMEOWmeowMEOW
Does fp stay the same when running, or does it spike or drop? You could have a restriction on the fuel system, or stuck injectors. What are you running for an intake, where is your maf?
How was it tuned?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-18-2014, 09:46 AM | #5 |
Evap plugged same o2 sensors with engine in c5 corvette manifolds no intake tube leaks same maf with engine. I have got spectra filter that was on a cold air intake that was on same avalanche that every thing else but the c5 manifolds came off of. Fuel pressure stays at 50lbs all the time. LTRT is about 18 at idle. Will check maf.
07-18-2014, 10:22 AM | #6 |
Mail order tune from PSI with harness. MAF is .70 at idle & 2.2 at about 1500rpm MAP 9.2 & 7.7. Unplugged maf did not change tried different filter no change.
07-19-2014, 08:20 PM | #7 |
Anybody????
07-19-2014, 08:44 PM | #8 |
Either your tune has a serious problem or you have a major vacuum leak. Fuel trim that lean could cause engine damage from pinging and actually running hot.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-20-2014, 10:39 AM | #9 |
N2oc
I am no way the man for this. But I had the same issues super73 helped me as he is a tuner and lives 1 hr or so away from me. What we did was disconnect the yellow wire on my blade style MAF. He did tune the engine and trans and then disabled the MAF in the tune. I am talking about the MAF part not the intake temp part. Since then my numbers have been good...also,he ran the wide band o2 sensor on it and dialed the AFM as we road Dyno'd it. I am probably missing 90% of what he did. But hope this helps!!! Probably best to take to someone after you have done some research. Good luck
07-20-2014, 11:03 AM | #10 |
Firstc10, glad it is running good.
Not2...I am surprised that that truck is supposed to be 50psi pressure, doesn't sound right to me. Pull out the single wire for the maf from with the pcm or maf it self. You will have a ses light but it will put you in speed density mode. Go drive the truck gently for an hour or so and the take a reading on you ltft's. You have to understand that ltft's are really your stft's that are averaged over time so it takes a little driving for them to average the other direction. If that does not show some results, then either the fuel pressure has it all messed up or the VE table in the tune is off.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-20-2014 at 11:15 AM. |
07-20-2014, 12:07 PM | #11 | |
meowMEOWmeowMEOW
...and then they moved the FPR into the fuel sending unit the years after. So go figure.
07-20-2014, 07:56 PM | #12 | |
07-21-2014, 12:17 AM | #13 |
meowMEOWmeowMEOW
No I'm agreeing with your original thought of 50psi. Thats the correct FPR, it just happens to be very unusual, since that design wasn't really used on many engines compared to the 58psi unit.
07-20-2014, 09:47 PM | #14 | |
Also, you may want to check that your tuner didn't flash a "canned tune" for you that has injector data for a fuel pressure of 58. As you've probably already guessed that would cause your problem as well. |
07-21-2014, 08:13 PM | #15 | |
07-21-2014, 08:33 PM | #16 |
I think whabrew is asking is, is there any incoming air supplied to the motor after the maf. Ie, some throttle bodies have a hook up for a valve cover. If everything is closed in the crank case including valve covers, this would pull a slight vacuum in the crank case. If one valve cover had the tube to the throttle body and the other is vented to the atmosphere, you will be pulling unmetered air in to the motor that is not being read by the maf.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-21-2014, 08:41 PM | #17 |
Hose from passenger side valve cover to throttle body, everything is the same as it was in the avalanche.
07-22-2014, 02:27 PM | #18 |
FIXED took out the ses light bulb and put the scan tool on the shelf.
07-22-2014, 04:53 PM | #19 |
meowMEOWmeowMEOW
If your actually hitting ltft's near 25 still....all you did is pull the pin on a handgrenade.
07-22-2014, 07:29 PM | #20 |
07-22-2014, 09:09 PM | #21 |
meowMEOWmeowMEOW
There are 2-3 in the Memphis area I've heard of. Thats East TN isn't it? I only know TN from portions of 65 in the Nashville area, never spent time east.
07-23-2014, 07:08 PM | #22 |
07-23-2014, 07:16 PM | #23 |
meowMEOWmeowMEOW
yes because memphis is WEST and I'm really effing stupid. I looked on a map, and found the WESTERN most city...and asked you, who lives in EAST TN, if it was close. Thats a colossal facepalm for me hahah
Are you closer to knoxville, or what about a few hrs to GA? I know a few that way as well.
07-23-2014, 07:26 PM | #24 | |
07-22-2014, 09:09 PM | #25 |
What year pcm?
