Old 07-18-2014, 09:26 AM   #1
handy67
shortening frame and bed???
I know there has to be a sticky or a thread already on this. Not trying to open a new one or start over but i'm having a horrible time finding anything and the stuff i do find is overly confusing. Can anybody send me a link or to a sticky so i can try to figure out how to shorten my frame and bed on my long bed to convert over to a short bed. Im trying to figure out if my C-Notch in the frame will affect where i cut or if its still possible. Thanks guys
handy67 is offline   Reply With Quote
Old 07-18-2014, 09:37 AM   #2
turp mcspray
turp mcspray's Avatar
Re: shortening frame and bed???
The cut will be under the cab. Really easy to do. Somewhere is a link to a "how to" I think.
Some people will tell you it will end up in a dumpster, but unless you are a complete idiot that can't follow directions, or use a tape measure, it is pretty hard to screw up.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-18-2014, 09:46 AM   #3
Scorp
Online Painter
Scorp's Avatar
http://www.youtube.com/watch?feature...&v=6o2k6QoERio
Scorp is offline   Reply With Quote
Old 07-18-2014, 09:46 AM   #4
R.L.
R.L.'s Avatar
U-Tube has a few videos on the subject.
R.L. is offline   Reply With Quote
Old 07-18-2014, 09:48 AM   #5
handy67
awesome thanks guys i'll try looking up on youtube
Old 07-18-2014, 11:10 AM   #6
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Their is the correct way and the not so correct way ,,,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 07-18-2014, 11:13 AM   #7
Scorp
Online Painter
Scorp's Avatar
Oh my
Old 07-18-2014, 11:33 AM   #8
handy67
hahahaha i would say that is a great comparisson of right vs wrong
Old 07-18-2014, 09:51 PM   #9
Fitz
I didn't know the three stooges worked on trucks. Awesome!
Fitz is offline   Reply With Quote
Old 07-18-2014, 11:07 AM   #10
19673ontree
CAN'T FIX NOTHIN
This is hands down the best thread ever posted on making a shortbed out of a longbed ! Read every post look at every pic !
http://67-72chevytrucks.com/vboard/s...=peach+orchard
underdash AC
Old 07-18-2014, 11:43 AM   #11
RManson
You can leave the cab on and make the cut behind it as well. Here's the story of my '68 where I shortened a longbed frame...
http://www.customclassictrucks.com/t..._c10_shortbed/
Like mentioned above, pretty simple if you can read a tape measure and weld.
I didn't even attempt to cut the sheetmetal down. Way too much work in my opinion and there are better options out there if your bed sides are rough. Good luck!
RManson is offline   Reply With Quote
Old 07-19-2014, 07:56 AM   #12
handy67
Hey Rmason if you do the cut behind the bed do you still need to move cab mounts?
Old 07-19-2014, 09:11 AM   #13
19673ontree
CAN'T FIX NOTHIN
No if you cut behind the cab you would not have to move the cab mounts , the reason for the cut under the cab is that you have room to do a overlap cut like pictured in the thread I posted of the guy that did the green 68 thats the very best way to do it , but now let me say this , I do not recomend it ! I would get a shortbed truck , but done correctly it can be fine to shorten a longbed ,,,,
underdash AC
Old 07-19-2014, 09:16 AM   #14
19673ontree
CAN'T FIX NOTHIN
This pic shows why you want to do the cut under the cab
underdash AC
Old 07-19-2014, 12:41 PM   #15
Turbo1dr
Turbo1dr's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1230866461
That's exactly how I would do it.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 07-19-2014, 12:09 PM   #16
RManson
If you make the cut where I did, it bisects the cab mount So yes, you'll need to remove the mount and reattach it. No big deal, but it is extra work. Now, it was a lot easier than removing the cab and front clip. I didn't want to do a complete frame-off at the time (though in the long run I may as well have! lol).
I like the 'S' cut and all that, but a good ol' 45-degree cut is all it takes to do the job properly. I think the key here is knowing what your capable of and doing a nice job. That 'S' cut could cause a lot of problems if the person making the cut gets a little too happy with the saw, etc. Ever try to make 4 perfectly curved cuts with a Sawzall? Just cut it straight, fish plate it on the inside, and box the entire section. Done and done.
Good luck!
Old 07-20-2014, 11:55 PM   #17
Bigbob
nolimitengineering.com sells a conversion kit that bolts on after you cut the frame. I haven't found any information about actual installation on this forum but I'm very curious because I am looking at doing the same thing.
Bigbob is offline   Reply With Quote
Old 07-21-2014, 12:09 AM   #18
sprint_9
sprint_9's Avatar
Here are the ones I plan to follow. Also a good tip, start a spread sheet to keep track of stuff you find or put it in your favorites within your browser. Sounds easy but more times than I can think of I forget and spend hours looking for it again, I had these two saved.
http://www.67-72chevytrucks.com/vboa...d.php?t=123624
http://67-72chevytrucks.com/vboard/s...d.php?t=509442
sprint_9 is offline   Reply With Quote
Old 05-06-2016, 04:03 PM   #19
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
https://youtu.be/6o2k6QoERio
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-12-2016, 11:40 PM   #20
69chevytrucker
69chevytrucker's Avatar
i cut a long box up and put it on a 83 blazer frame lol but im just a little nuts
69chevytrucker is offline   Reply With Quote
Old 05-13-2016, 09:21 AM   #21
Shady Rascal
Shady Rascal's Avatar
Originally Posted by 69chevytrucker View Post
Attachment 1532193
Attachment 1532195
THAT'S VERY UNSAFE !
That shop heater in the first picture is supposed to be mounted near the ceiling, not the floor.
Strange way to store your truck too.
Shady Rascal is offline   Reply With Quote
Old 05-13-2016, 09:57 PM   #22
69chevytrucker
lol its hard to keep stuff in the box
cant get the pic to go right side up
Old 05-14-2016, 01:21 AM   #23
66clow
66clow's Avatar
This is the way to go.
http://67-72chevytrucks.com/vboard/s...bed+conversion
66clow is offline   Reply With Quote
