07-22-2014, 12:38 AM | #1 |
Looking for something with better flow than stock manifolds suggestions
Looking for some ideas on replacing the stock manifolds. Will the vette or camaro ones bolt on so that the exhaust is easy to put on or are headers a better way to go. Or should I just leave the truck manifolds
07-22-2014, 05:05 AM | #2 |
Fabricate till you "puke"
Re: Looking for something with better flow than stock manifolds suggestions
I don't think that you will find the truck manifolds to fit on the LS swap. The trail blazer ss manifolds have been used, & look to fit well on an auto trans app. I used a set of Hooker streetrod shorties, as they cleared all of the mechanical clutch linkage. Auto trans, or hyd clutch setup, you have more choices? I will let the rest of the guys "chime in", as to app & fit...Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-22-2014, 08:45 AM | #3 |
I did run a set of ls6 manifolds off a zo6 they fit, I then swapped to a set of midlength Camaro manifolds, I now have a truck manifold on the drivers side plumbed into a turbo.
I made my own mounts and did slightly "clearance" the top of the frame rail. It was slight. I do remember an article in hotrod a year or 2 ago and they did dyno testing, the ls6 style performed within 2 or 3 hp of headers. I believe the trailblazer manifolds are similar. Unless you are building a high reving high horsepower motor I don't think you will see a lot of difference between anything you use. You can chase the last few hp with a lot of dollars.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-22-2014, 10:27 AM | #4 |
how does the Camaro manifolds flow compared to the truck ones? I was gonna go with headers but was told the Camaro ones I got flow great and don't need headers.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
07-22-2014, 12:47 PM | #5 |
http://ls1tech.com/forums/generation...manifolds.html
http://www.carcraft.com/techarticles...e_header_test/ check out these 2 articles. There is probably a ton of other web information. I just remember the carcraft article.
