Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-23-2014, 08:28 AM   #1
TEXAS 65
Question to the 60-66 drag trucks
I have a 65 GMC swb step that I have back halfed with ladder bars and coil overs and taken all crossmember out and replaced with tube, wud love to post pics but all I have is iPhone and can't figure it out. Anyways I'm ready to start wrenching on front end and was wondering what y'all are doing up front to help your trucks, I don't have a lot of money, all parts so far are donations from older cars I made to fit and tube I had laying around so I can't afford those nice bolt in replacements I've seen for sale, but do have a lot of junk yards around to scrounge for parts. Thanks in advance!
TEXAS 65 is offline   Reply With Quote
Old 07-23-2014, 10:37 AM   #2
Super73
Super73's Avatar
Re: Question to the 60-66 drag trucks
My current set up:
Home built cross member retaining factory geometry for lower control arms (20lb savings)
Stock upper / lower control arms
Rancho 9000 adjustable shock, I had to add a little ear at the top of the frame to mount it
Front coils from a late 80's/early 90's V8 Grand Cherokee (17 3/4" long and roughly 200lb rate)
CCP drop spindle
Stock front disks from a 67-72 pick up
I am however in the process of putting a MII spindle in the truck utilizing QA1 ball joints. I will be updating the thread I have here next week once I have parts in. But this should save 75+ lbs
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-23-2014, 07:10 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Super73 View Post
My current set up:
CCP drop spindle
I'm interested too. You have a similar setup to me. Same brakes (with d52s), spindles, springs. I've got adjustable qa1s and love the difference they made. I'm super interested in your crossmember setup, as I feel like the stock one is heavy and bulky for no reason.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-23-2014, 03:39 PM   #4
TEXAS 65
Awesome, thanx super73!
Old 07-24-2014, 08:29 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
I didn't do much to my 66, I hung a stock 1972 1/2 ton manual disk brake truck front end under it. Wasnt that much different than the 66 except for the taper for the spindles and I could get 2" drop spindles for the GM disk brake and 5lug pattern. Then relocated the shock mounts so I could use a set of cheepie CE drag shocks (set at 60-40) Put a sway bar under it to help control the body roll when lifting on the top end.
A more drag truck worthy suspension would probably be a bit quicker than the 10.6's it ran at 3650 pounds,, but the 60' was fairly consistant 1.44 so I figured,, what the heck. But I got a LOT of tire and years in getting the 4link where it worked on this pig. Now it doesn't care if it's got a 450HP motor or 650,, it dead hooks and tries it's best to tear things up.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-24-2014, 08:42 AM   #6
TEXAS 65
Thanks Marv D , like to hear mostly stock swap works great! My kinda budget. I do have my highschool 79 trans am yet, wuts left of it anyway, wut y'all think about choping the existing rails in front of cab and fabing the t/a front in there?
Old 07-24-2014, 08:44 AM   #7
TEXAS 65
Super 73 I wud really like to see sum pics of your crossmember as well!
Old 07-24-2014, 11:24 AM   #8
Super73
Super73's Avatar
Let's see if this works, first time uploading from my phone.
2x4 .180 wall. I built a jig to the old cross member while in the truck and no suspension on it. I plated where all the seems were for the square tube and gusseed the play that the lower control arm mounts to. Not pretty but it works.
Old 07-24-2014, 03:17 PM   #9
TEXAS 65
I like it! Thanx
