08-06-2003, 10:23 PM | #1 |
T-case lever bolt Q
I have an adaptor I bought to mate my SM465 to an NP 205. The threads for the handle bolt are 7/16-14. The bolt I have that fits the handle is 1/2 inch. Is there a handle bolt with 7/16 threads that I need, or should I just drill and tap the adaptor for the 1/2 inch bolt. A straight 7/16 bolt is too small for the handle. Thanks!!
69 GMC K10 ..some restoration required....still.. |
08-06-2003, 10:30 PM | #2 |
There is a bushing that goes on the 7/16 bolt to take up the slack.
I made a new one out of nylon cause mine were shot.. Randy
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-06-2003, 10:40 PM | #3 |
OK..maybe my bushing is worn that much too,but...it fits a 1/2inch bolt good. Thought maybe there was a 1/2 shank bolt with 7/16 threads ??
08-07-2003, 08:05 AM | #4 | |
Tim |
08-07-2003, 09:17 AM | #5 |
Standard shoulder bolts with 1/2" shank have 3/8-16 thread. A 1/2" shank with 7/16-14 thread is probably going to be a special
as indicated. Jim |
08-07-2003, 10:54 AM | #6 |
Class,
When I swapped my straight stick 205 for an auto 205 I bought a new bolt from the General. The updated bolt has a zerk on the end so you can squirt grease in there. There was room so I put some nylon washers in there too. Between the nylon and the grease it doesn't rattle around like the old one. I HAD a part number. If I can find it I'll post or email it to you. If worse comes to worse I should have a box in the shed that has my old bolt in it. It Might fit your application.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-07-2003, 10:55 AM | #7 |
Bolts
The 7/16 bolts were for 4 speeds, and the 1/2 bolt was for AT adapters.
I have a new 7/16 adapter bolt I would sell you for $10 bucks, PM for pic. |
08-07-2003, 08:47 PM | #8 |
mrein3...the greasable bolt sounds very interesting! I had planned on tapping the handle for a fitting, this would be better. I PMed 72Bob for a pic of his. I'll see what it looks like. Thanks all
08-07-2003, 09:25 PM | #9 |
PM'
Class of 69
PM returned with pic. |
08-09-2003, 08:46 PM | #10 |
pic of newer type.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
