07-24-2014, 05:17 PM | #1 |
New Here, my first rebuild....EVER
Hey all,
Just found this site, and just found this beauty. My neighbor had it and he was going to redo it for his son, but his son didnt want it and he ran out of time and money. So, I bought it off of him. I have a multitude of questions to ask, but will take my time asking them. I have never rebuilt anything, and I know nothing about engines. Nothing. When I bought it, the only way it ran was to run a hose in to a gas can straight into the fuel pump. I limped it over to my yard and went to work. I learned how to change the fuel pump, and learned about the fuel sending unit as well. I followed the fuel lines along the frame and learned how they worked. So far it has a new fuel pump, new fuel lines, and she runs like a champ. I think I've done fairly well for the lack of mechanical knowledge I have . I know I have tons more work to do, but I hope to do it all on my own. Wish me luck!!! Stats: 1967, 283, 4-speed on the floor Last edited by kcsa75; 07-24-2014 at 06:18 PM. |
07-24-2014, 05:22 PM | #2 |
Cluster King
Re: New Here, my first rebuild....EVER
Welcome to the site. You will have all of the support you need here for what ever issues you will run across. My first question to you is how old is the gas in the tank? You will probably want to start right away with pulling the fuel tank and making sure it is clean inside (no rust). Anything loose in there will give you problems in the future.
Also clean or replace all of the fuel lines from the tank right to the carb. New fuel filter and even a carb rebuild if needed. Most importantly, have fun and learn as much as you can. That is a nice looking truck to start with by the way Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
07-24-2014, 05:54 PM | #3 |
First thing I would do is to replace all the fluids.
...engine, transmission, differential ect. Enjoy your new toy! Welcome to the forum! |
07-24-2014, 06:19 PM | #4 |
Welcome! You're among friends here. Looks like you have a great start!
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
07-24-2014, 06:54 PM | #5 |
welcome. a lot of good info on this site. nice truck as well.
07-24-2014, 07:05 PM | #6 |
Do yourself a favor and keep everything from your truck when I got mine I tore into it threw stuff away gave stuff away and just plain lost stuff I wish I had some of those things now take your time and enjoy and welcome from illinois, oldno7
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. oldno7 |
07-25-2014, 10:36 PM | #7 | |
Also, welcome.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
07-24-2014, 07:26 PM | #8 |
Welcome to the Forum, nice lookin truck.
07-24-2014, 08:02 PM | #9 |
Man that is a clean looking truck from this neck of the woods. Looks like a great start and welcome. What are the overall plans for it
07-24-2014, 10:41 PM | #10 |
Congrats on the truck. It's really cool that you are jumping in head first and learning. I learn things every day on this site. Subscription was money we'll spend!!!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
07-25-2014, 02:03 AM | #11 |
Welcome to the forums. Also, that's a mighty fine looking truck to start from. Here's to hoping you find the mechanical work as much fun as I do.
07-25-2014, 01:38 PM | #12 |
Hey all, thanks for the welcome! My initial plans are to get it running and make sure it runs correctly. I have a 5 year old son and would like to build a nice hot rod for him before he turns 16. I have all these plans in my head, and by looking at some pictures of trucks on here, I get alot of nice ideas. For now though, I'll probably drive her around town for errands and things. Oh, I forgot to mention, she only has 73,000 miles on the original motor. I do have one question tho, the fuel filter running from the pump to the carb, should that be there? I replaced it, but when I look at new fuel lines I dont see one.
07-25-2014, 01:49 PM | #13 |
it didn't come from the factory with an inline fuel filter between the pump and carb, but it's always a good idea to add one there. Most everyone does. The only filter from the factory is a tiny little paper one inside where the steel fuel line goes into the carb. I would replace that one too as it can be completely gunked up and or collapsed. Good luck on your build!
07-25-2014, 03:47 PM | #14 |
i'm diggin the red interior
07-25-2014, 03:58 PM | #15 |
Welcome from Utah. I notice it's got an EFI distributor. Check the voltage and make sure you're getting enough power. The power that ran the old coil would have been run through a resistor wire to drop the voltage.
Lovin' the 'Vise-grip' window crank. lol
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
07-25-2014, 06:06 PM | #16 | |
One thing to do?check? is to make sure you have ground wire(s) from engine block to fire wall, can make a big difference. All those old chevies (cars and pickups) had ground straps from rear valve cover bolts to firewall, and got thrown out, first time valve cover gaskets got changed... That carb would have had a bronze (rock) filter in carb. They worked, but if much crap got into them, the bypass spring would allow crap to get by. I'd keep the in line filter, but am paranoid about some of the plastic inline filters. The filter in picture is an old Fram brand, they were O.K. I prefer a metal filter. Be careful if you decide to check for the in carb filter, those threads strip real easy. You do not need the in carb filter, when keeping the in line filter.. Make sure you use gas w/o ethanol if possible, ethanol in carbs can be a problem. Changing fluids is a good thing. Next is repacking front wheel bearings. If you change the rear end oil, you'll have to remove the cover. Pay attention to the oil, make sure it has no glitter in it. It would be nice to check/replace the rear axle bearings, and seals. Not a difficult job, but first time isn't easy. Suck the old brake fluid out of master cyl, fill w/ new dot 3 fluid. Drive it around some carefully, make some stops where the brake pedal needs to be pushed hard, this can be done at even 2-3 mph. This will test the hydraulics to make sure you have no leaks. Look at inside bottoms (from under truck)of drums to see...and ck master cyl level. I'm amazed the overall great condition!!! Even w/ low miles. Obvious the seat was re-done, looks good!!! The tell tale sign of these pickups is the condition the the rocker panels (curved panel below doors). If they have no rust in them, that's very unusual. When I see a 67-72 w/ good rockers, I know they're not original!!! LOL Can't wait to hear/see more. A plain pickup, but man you got a nice one, I like simple things... Last edited by 68Gold/white; 07-25-2014 at 06:29 PM. |
07-25-2014, 07:01 PM | #17 |
I hadn't heard that before, but it sounds reasonable.
07-25-2014, 10:29 PM | #18 |
Ok, the switch location deal pertains to cars 68 and before were in the dash 69 and later were in the column. hope that helps some. Great looking start on a project, nice truck. Welcome to you from Arkansas. I would make sure the brakes and suspension are safe then enjoy!! Ask all the questions you want there are no stupid questions, your in a safe place and if you don't know how else do you learn except by asking? I would tell you to go to the FAQ section of the home portion of this site in the upper left hand corner of the main page. Go to the 67-72 section and then also go to tech tips for the 67-72 and find many cheap and EASY and sometimes FREE ideas for the upgrading or enhancing of these trucks. Enjoy. Jim
07-25-2014, 05:17 PM | #19 |
Moderator
Hi and welcome to the site! Great looking project you have there.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-25-2014, 05:53 PM | #20 |
Brain fart. lol I meant HEI not EFI distributor
