Old 07-30-2014, 02:13 AM   #1
Mick Je
Mick Je's Avatar
Getting Hot on the Freeway
Ok, my 1970 GMC has now had all the different cooling ways you can do: The stock clutch fan, Flex Fan, and now electric fans. My truck has a mild 402 .30 big block. My trouble is with the electric fans, everything is good around town, but once I start going over 55mph (spinning 2200 rpm) with A/C on or not on the fwy, the truck eventually starts getting in the 220-230 range and that's way too hot!!! But if I get stuck in LA traffic it cools and runs good! Before I got these fans I did a lot of research comparing other brands and I got the Derale Dual High Output fans (4,000 cfm) with their high output controller. In the future I would like to add a gear vender to lower the rpms. So far I changed thermostats from 180 to 160, then I took the thermostat off and currently trying water outlet restrictors. I was wondering if any of you guys have ideas that might help.
These are the fans I have.
343 NEVER FORGET 9-11
FIGHT ON!!! GO USC!!!
PROUD OWNER OF A 1970 1/2 TON
Mick Je is offline   Reply With Quote
Old 07-30-2014, 08:05 AM   #2
geezer#99
geezer#99's Avatar
Re: Getting Hot on the Freeway
You need an air dam under the rad. You need to create a low pressure area behind and below the rad so that the high pressure air can flow thru the rad and down into that low pressure area.
Old 07-30-2014, 08:20 AM   #3
volksworld
this is an incredibly stupid question but are they spinning in the right direction?
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-30-2014, 09:09 AM   #4
airdale94
airdale94's Avatar
I would try removing those covers on the shroud (above and below each fan). It sounds like you're not getting enough airflow at highway speed. The 4th Gen F-bodies have a dual fan setup that has flapper doors on the shroud that open up at higher speed and allow more airflow. Might check your A/C condenser also. Blow it out with air and or water.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 07-30-2014, 11:24 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Something is wrong with your cooling system. Your vehicle should not need a fan of any kind after about 45 mph, even on a 120 degree day.
Put the thermostat back in. If the water is just constantly circulating it will never have a chance to cool.
I would look into a leaking head gasket, plugged radiator, or other issue.
What size radiator do you have? With a 402 and A/C you should be running a factory 4 row at a minimum.
I was thinking the same thing as well.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-30-2014, 12:16 PM   #6
Lee H
Lee H's Avatar
I agree, at speed the air is not adequately moving through the radiator. I think that flat shroud is causing a great deal of turbulence limiting the flow through the radiator. Is there any gap between the shroud and radiator? Air, like water, follows a path of least resistance.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-30-2014, 12:54 PM   #7
nzc10
nzc10's Avatar
I agree with 67chevyredneck sounds like a blocked radiator my girlfriends car used to do the same thing on the highway I removed the radiator and took it to the radiator shop who flushed it out found out it was 60% blocked no problems after that
nzc10 is offline   Reply With Quote
Old 07-30-2014, 01:09 PM   #8
LUCKTRUCK
LUCKTRUCK's Avatar
perhaps timing or air fuel mixture?
http://www.automotiveu.com/SolvingOverheating.htm
LUCKTRUCK
LUCKTRUCK is offline   Reply With Quote
Old 07-30-2014, 01:34 PM   #9
Mick Je
Mick Je's Avatar
Before I put the electric fans on
-I put on a Weiand Water Pump
-I had to re-core the radiator and its a repro bass stock big block one
-New Water hoses and coolant
And when I got the fans I took those flappers off. The fans are designed for puller applications and fits my radiator coils perfectly with a 2" gape between the fan and coils.
And it starts getting hot over time going 55 mph and over.
Old 07-30-2014, 01:37 PM   #10
Mick Je
Mick Je's Avatar
I do have a engine oil cooler and trans oil cooler in front of the condenser and radiator.
Old 08-01-2014, 12:22 PM   #11
67 cst swb
67 cst swb's Avatar
My thought is...
He either got ripped off on the re-core job or is being told that his current radiator is shot and needs a new radiator now, when this one is actually fine.
Unless of coarse, he used a Hi-Volume water pump also and everything is just passing through the system too fast and not getting a chance to cool.
I will just be interested to see the outcome.
It will be great if it solves the problem, as I'm sure he's tired of this issue.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 08-01-2014, 12:55 PM   #12
Mick Je
Mick Je's Avatar
I thought it was but I look back in my records, and they only clean it and put new tanks on it last year. And I did see the inside of the core and it's ready. That core was a 4 row Desert Cooler that was from 97 that my records show. So I'm putting a 5 row and little bit thicker radiator in it now. So no I'm not getting ripped off or anything!!! This has to be the problem, because I always thought I had a coolant flow issue and that shroud can't block that much air.
Old 07-30-2014, 01:37 PM   #13
davepl
davepl's Avatar
The factory cooling system for the big block is more than sufficient.
The factory fan and shroud will move a lot more air than the box you pictured (unless those are some serious $400-per fans or something).
Remove random pieces of the factory setup (like the shroud) and all bets are off.
How's your vacuum advance?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-30-2014, 02:57 PM   #14
marcus.boldt
If it was me, I would take it out on the highway and let it start heating up, then find a safe spot to work on it, and remove the fans and the housing. Jump back on the highway and see if it's worse at 55 or if it starts cooling.
Personally I think at highway speeds, those fans are just in the way.
marcus.boldt is offline   Reply With Quote
Old 07-30-2014, 03:04 PM   #15
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Before any of that id definitely verify the fans are spinning the right direction just turn them on and hold some tissue in front of the radiator. If it pulls the tissue toward the radiator its correct. If its blows it away fix the problem. All of the above are posts are very good advice. The fan direction is just easy to check first.
Oldtruckfanatic is offline   Reply With Quote
Old 07-30-2014, 03:06 PM   #16
HalfCaseKustoms
I have a stock set up on my 350 and having the same problem. Fine around town in any temp. Over heats on the highway
HalfCaseKustoms is offline   Reply With Quote
Old 07-30-2014, 03:49 PM   #17
airdale94
airdale94's Avatar
Might check timing like LUCKTRUCK said: Also make sure your waterpump bypass/heater core(hot) is plumbed, both you and HalffCaseKustoms. I know some don't use them on both big blocks and small blocks. But I have a 283CI and I had 76CC 350 heads on it and I put a shutoff valve on the heatercore feed. No problems. Swapped to some HO 305 heads and I would overheat on the highway. Opened up the shutoff valve and overheating went away.
Old 07-30-2014, 04:01 PM   #18
67ChevyRedneck
Also check for a vacuum leak.
I just remembered a couple months ago I needed a longer vacuum hose immediately for a trip in my mustang (was literally about to leave for the Hot Rod Power Tour) and I stole it from the C10's vacuum advance. I then forgot I did that. Truck ran kinda funny, but temp was OK at idle, but was getting up to 215-220 on interstate. Scratched my head a bit, then remembered the missing hose. Put it back on and truck was fine... so could be a vacuum leak too (or timing as already mentioned).
Jesse James
Project "On a Dime"
Old 07-30-2014, 04:15 PM   #19
truckdude239
truckdude239's Avatar
Lower hose colposing under load
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-30-2014, 07:03 PM   #20
slomotion
Old Duffer
slomotion's Avatar
Do you know for sure your gauge is accurate?
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 07-30-2014, 08:40 PM   #21
Acorn
X2 or 3 on checking your timing and advance. It never hurts to check it anyway.
Start with some basic troubleshooting. And don't get such tunnel vision that you miss something simple.
When did this problem first start? Did it cool fine with stock fan? Try driving on the freeway but drive slower. Like 500 -1000 rpm slower and see if that makes a differance.
Everyone here is giving good advice. (as they always do!) It's bound to be something simple. Maybe take a brake, clear your mind and start over when your fresh.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 07-31-2014, 01:55 AM   #22
Mick Je
Mick Je's Avatar
Well just found out that my radiator core is shot, which I thought that was all good, but that should be the problem. Thanks for all the ideas!!! Getting a new brass core tomorrow!
Old 07-31-2014, 09:20 AM   #23
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I thought you already re-cored the radiator. ??
PS how about a link to see more pics of your truck?
Tom Vogel is offline   Reply With Quote
Old 07-31-2014, 09:51 AM   #24
This was obviously a coolant flow issue and first thoughts go to radiator. I saw it was cored and was stumped. It would have had to been something else restricting (or not giving...water pump) flow. Thoughts kept going back to question radiator work. I'm not surprised. Now just baffled at what wasn't done that was said to be done?
Old 07-31-2014, 11:48 AM   #25
67 cst swb
67 cst swb's Avatar
I will be interested to see whether a new radiator fully fixes your problem.
All that aluminum looks pretty holding those fans, but its acting like a stop sign for the air at highway speeds. (especially if your fans are spinning backwards)
My Trucks:
