07-31-2014, 08:11 AM | #1 |
67-72 air conditioning swap?
Does any one know if the 73 up to? air conditioning will fit in our 67-72 trucks couldn't find any thing on this i see Vintage air 1400. if 73 up fits will be a lot cheaper im on a no budget.lol Don't mind investing the time .Thanks Oz
07-31-2014, 08:47 AM | #2 |
Re: 67-72 air conditioning swap?
Not easily, particulary on the inside.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-31-2014, 09:13 PM | #3 |
08-04-2014, 08:57 AM | #4 |
How are you going to put the hoses to the vents? 67-72 has round "dryer vent" hose. 73-87 has plastic boxes that direct the air. The heater core comes out different. The controls are different. Lot of fabricating.
07-31-2014, 01:39 PM | #5 |
The 73-87 evaporator will fit in the 67-72 box, the compressor will fit if you have all the right brackets. Some hose fabrication required.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-31-2014, 09:15 PM | #6 |
I will check out putting the evaporator in the 68 box that would be the hard part .Put a better blower in and the rest is not bad to do.Found a company that makes brackets for big block chevys so you can use small block serpentine belt set up .Costs 150.00 i am going to run a sanden 708 compressor.
08-04-2014, 05:08 PM | #7 |
Have you done this ?If you put the evaporator in how do you work inside the cab?Put a water shut off for the heater core and install a better blower motor?And i suppose you could adapt out going hoses and install side vents?Just thinking aloud .
07-31-2014, 09:19 PM | #8 |
I used the 73-up evap from classic industries and accumulator/orifice tube to eliminate the POA, sanden 508, vintage air brackets and parallel flow condenser, fabbed hoses and hard lines, working like a champ for 6 years now
08-01-2014, 12:09 AM | #9 |
I am going to make a list of what you used thanks for posting i knew someone had done it .ha ha
08-01-2014, 01:27 AM | #10 |
Moderator
If you are going with R134 (which is most likely) a parallel flow condensor is key in achieving cold air in all driving conditions/temperatures.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-01-2014, 11:20 PM | #11 |
Yes sir that condenser is key, electric fans would be even better but haven't got around to it yet. I would even say, as much as I hate to admit it, that it probably works better than it did with r-12. I can probably get some part numbers and pictures up just give me some time.
08-03-2014, 02:04 AM | #12 |
08-03-2014, 09:07 PM | #13 |
Thanks guys for all the info looks like its helping some other members too!The more info i get the more inclined i am to build my own set up .
08-03-2014, 12:43 AM | #14 |
Is there a place that sells an updated/high efficiency condenser that will fit without mods?
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
08-04-2014, 04:49 PM | #15 |
I have one from Classic auto air.. it fits nicely in the original condenser mounting holes. Even so I still had to drill a hole for the upper condenser line. barely visible but painful to do nonetheless.
1972 K-10 SWB Cheyenne |
08-02-2014, 12:29 PM | #16 |
Its a Truck Thing......
Look at my post about changing to a serpentine system. This could give you an idea. Look at #22.
http://67-72chevytrucks.com/vboard/s...d.php?t=468729 Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
08-02-2014, 08:32 PM | #17 |
Thanks im going with a serpentine set up that uses small block pulleys and brackets on a big block its cool Kwik performance inc.
08-04-2014, 07:08 PM | #18 |
http://67-72chevytrucks.com/vboard/s...d.php?t=473921
I looked extensively into this but have not got to this stage yet. The Sanden enhanced S7 is a very high performance compressor that equals the one that came stock in our year models from what I understand. The 508 is acutally pretty small from my research and so I am going to put the more powerful compressor in. I plan on doing as Clinebarger has suggested as it is simple and makes perfect sense. Check out the link and see what you think.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
