Old 07-31-2014, 08:27 PM   #1
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
72 K10 Front driveshaft question
Hello everyone. As I'm reinstalling the front driveshaft in my 72 k10, I've noticed pictures of many other trucks that are different than mine. I see most others have an extra u-joint and flange on the transfer case end, making for a total of 3. Mine has only 2 U-Joints that bolt directly into each yoke. I believe the truck has a 2" lift, but I don't think that should require a new front shaft. Has anyone seen one like mine without the flange? Should I look to replace mine, I don't plan on using the 4wd more than maybe one per year but it would be nice to make sure it works properly. Pictures are best I could do from way back in the teardown days...
Best pic I have, see where it connects to the t-case directly
The style that I've seen elsewhere
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 08-01-2014, 08:32 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: 72 K10 Front driveshaft question
I have had a couple of these trucks and have always had a "double-cardian" joint at the transfer case. The older ones used the dana style and the newer ones used the sagnaw or flanged style. From what I can tell in your pic, typically the slip joint is always bolted at the axle not at the transfer case. I can take some pics of mine when I get home.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-01-2014, 09:13 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
Yeah as Jim said; You should have a CV joint ( double u-joint ) at the transfer case and the slip joint down towards the diff.
I did have a shaft like yours on a truck temporarily until I got a replacement.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 08-01-2014, 12:58 PM   #4
61K10
61K10's Avatar
why would you have the slip joint down in the mud and water? my tk only has 2 u-joints, one on each end plus the slip joint. don't have much axle movement though.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-01-2014, 02:46 PM   #5
FlameOut
Here is a picture of mine, from my 72 SWB K10
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 08-01-2014, 04:46 PM   #6
dave666693
dave666693's Avatar
Attachment 1284545
this is the correct set-up
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 08-01-2014, 03:16 PM   #7
67swb72klb
67swb72klb's Avatar
I have seen people run without the cv joint but they should have them
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-01-2014, 05:06 PM   #8
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Interesting. I guess I'll have to look for the correct shaft. I wonder if I can just add the cv joint to the shaft I have?
-NICK
Old 08-01-2014, 06:29 PM   #9
kwmech
No the double cardian will have to be welded to the tube and rebalanced.
Old 08-01-2014, 07:13 PM   #10
jjzepplin
jjzepplin's Avatar
I happen to have a good cardian joint on a shaft I stole the spline from... $20 plus shipping.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-01-2014, 09:38 PM   #11
franken
The shaft angle is improved slightly by adding the lift. It seems a PO thought it was enough to not need the CV joint. He may also have also spent some bucks converting from the flanged output to the ujoint output, which many feel is better.
Mark how the splined ends go together to keep it balanced, pop the shaft in two, clean, grease the splines and the ujoints and forget about it.
BTW, stop looking at LMC catalogs for locally available common replacement parts.
Old 08-01-2014, 09:47 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good advice, and here's why, along with a good basic illustration of why DS angles need to be correct.
https://www.facebook.com/photo.php?v=470937339716400
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-04-2014, 11:55 AM   #13
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Thanks for the info. This truck was caked in what looked like Georgia mud when I got it. So i assume a PO had been running it through the mud without any 4wd problems. I wont be wheeling this truck hard or often so i think i'll take your advice and just clean up what i have.
BTW- I stopped shopping at LMC many years ago but their catalogs are a decent source for parts pictures.
-NICK
Old 08-04-2014, 11:07 AM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Mike, That is an awesome link. Thanks for sharing!
