fuel gauge question
i think I've asked this before, but is there a way to make this auto meter fuel gauge work without changing out the sending unit??? just seems like huge pain in the butt to do and has to be another way to make it work
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
meowMEOWmeowMEOW
Re: fuel gauge question
find the output range on the sender, and the input range on the gauge. I've used resistors to make aftermarket gauges work with the 70's sending unit.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
so i just put the resister on in-between the sender and gauge?
Oh that's easy enough I think
I wish I could get my stock one to work. I have anxiety about running out of gas...I don't even know how much gas is in it now
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
didnt you say in one of your other post that you dont have any gauges???
according to brw3, it seems like a easy fix, trying to find resistors in town here, i actually ran out of gas a while back, thought my fuel pump went out cause i couldn't hear it over the busy highway....
no I have my stock gauges but they don't work...im using the torque pro app with a elm327 Bluetooth connector for now.
that shows everything? water temp oil pressure etc???
Shows speed, rpm, water temp,volts,load, throttle input, oil temp(but no oil pressure which is weird), has fuel level display but its not working on mine... even has 0-60, 1/4 mile time, horsepower and torque display too
not bad...missing the two important ones tho!!!
meowMEOWmeowMEOW
If you search "fuel gauge resistor" you'll get a few threads on it. IIRC, a 45ohm resistor gets the oldschool gauge to work with the later sending units.
ok ill search for it too...I need my fuel gauge
So been crazy busy with work, anyone know the ohms on the autometer fuel gauge and the stock sending unit on my 84? Got a 87 sending unit if it matters
