Old 08-04-2014, 07:02 PM   #1
jondancer
Hose from air filter to valve cover ....
I installed a new a filter on my sbc and now I need a new hose that goes to what I believe is the Pcv valve in the valve cover. I tried installing a generic hose but the bend is to extreme So the hose crimps shut.
Do the make a pre bent hose ?
jondancer is offline   Reply With Quote
Old 08-04-2014, 07:26 PM   #2
truckster
truckster's Avatar
Re: Hose from air filter to valve cover ....
Mine has a metal tube with rubber hoses on the ends - the metal tube makes the bend, and the rubber hoses are only 3 inches or so long. Maybe you could find one like that at a wrecking yard.
truckster is offline   Reply With Quote
Old 08-04-2014, 08:21 PM   #3
haysonj
haysonj's Avatar
You should be able to buy that hose at a parts store it not you can get the plastic 90 in the heater hose dept and make your own.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-04-2014, 08:26 PM   #4
jondancer
Hope I can find a hose, I want it to look as clean as possible. If I install a 90' plastic elbow that would make for 4 visible hose clamps and I don't want that.
Old 08-04-2014, 08:49 PM   #5
haysonj
haysonj's Avatar
You don't need hose clamps and the plastic 90 is black so you hardly see it. That is only a vent line The PVC should go into the manifold or base of the carb.
Old 08-04-2014, 08:47 PM   #6
leddzepp
Moderator
leddzepp's Avatar
You can look on the parts board. OE setups come up for sale frequently
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-04-2014, 08:49 PM   #7
jondancer
I have the oe but it is a riser, and with my new Cadillac style air cleaner it sits to high with a riser
Old 08-04-2014, 08:50 PM   #8
jondancer
Should I not have the Pcv in valve cover?
Old 08-04-2014, 09:05 PM   #9
haysonj
haysonj's Avatar
The pvc should be in the valve cover and go to a vac source either at the base of the carb or directly into the manifold Here is a picture of a pvc valve with the hose going into the base of the throttle body
