GMC gauge cluster with electric coolant gauge not mechanical
Anyone have one? I pulled the Chevy style mechanical out and installed a GMC unit ( I liked the tan face that GMC had) but the temp gauge is electrical and I need to know which side is 6v ( I'm swithing to 12v) and which side to run my new light green temp sender wire.
I have searched and searched before asking and hat to pull out a multi meter and screw something up. If it has a nut and bolt, i'm your guy. if it has current running through it or breasts, I will screw it up. ![]() Standing on my head looking at the gauge mounted.....it's the lower right quadrant in this pic
GOD BLESS AMERICA! Last edited by NEWFISHER; 08-04-2014 at 08:51 PM. |
Re: GMC gauge cluster with electric coolant gauge not mechanical
The right upper quadrant is the fuel gauge. the red tag says " connect fuel sender here, if powered gauge will short"
I'm rolling the dice and connecting the coolant sender on the upper rt stud and power to the lower. No battery installed yet so I have some time if someone chimes in before I see smoke.
GOD BLESS AMERICA! |
I will look here in a little bit and get a pic of my 50 GMC electric temp gauge. Jim
Here's pics in my photobucket, there's a few you can look at to pick
http://s894.photobucket.com/user/eag...tml?sort=3&o=0 The green wire closest to bulb and white fuel guage resistor is the twelve volt reduced to six volt power supply to guage. Just out of sight is the voltage reducer. Do you have a part number for a sender. I think mines bad. Jim Last edited by eagleuh1; 08-05-2014 at 02:01 PM. |
Thanks Eagleuh1!
I will let you know if my sender works....its a 1967 NAPA unit for a 250 and the couter guy gave me the deer in the headlight look when I asked what Ohm it was.
What's the upside down pic for? Is that what it looked like for you? Sorry bout the crappy cell phone pics also. Jim
Stole it from your photobucket to show peeps. It helped as a reference tonigbt as i was lying on my head folded upside down. If it had been right side up i would have wired it wrong lol!
![]() Join Date: Jun 2002
I learn something every day! I didn't know that there was elect. temp gages in the old GMC's. Mine is mech.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Mines a 3 ton 450 series if that matters, not a "small truck". Don't know if half tons came with electric gauge or not. Jim.
