compression test LS1 , my results what do u think ??
Hy all
hope u can give me some feedback about my results of the compression test. cly 1 = 162 2 = 176 3 = 174 4 = 171 5 = 152 / with oil 159 6 = 181 7 = 192 8 = 200 I heard that between the lowest / highest compression shouldn´t be a difference more than 30%... Cylinder 5 / 8 is just within that rule of thumb.. But i am not really happy with the big difference.. What do u think.... ?? The engine has only around 50.000 mile on it. THanks Achim |
Re: compression test LS1 , my results what do u think ??
By GM rules the allowable low is 70% of the highest value. This puts your lowest allowable at 140.
How did you do the test, was the engine at operating temp and how many rotations? |
The engine was cold , cuz i already removed the engine out of the car...
I did 4 rotations each.. But i just recognized that i have missed to open the throttle wide open. Will do the test again...with WOT CU AChim |
Ya at operating temp is the best. One thing to pay attention is how fast it comes up on compression. If they all come up pretty quick (say first or second rotation) I wouldn't worry too much about it.
Cold tests can sometimes be all over the place. If you are really concerned I would do a cylinder leak down test. |
Boosted Member
I always prefer a leakdown test to a compression test, even though it's more work. Cranking compression test has too many variables that affect the numbers.
Plus, with a leakdown you can "easily" pinpoint where your compression is leaking to.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
