08-06-2014, 10:12 PM | #1 |
Kvn1011
Kevin's 1972 build thread (slow motion)
Hello all, i've been lurking on this board for about 4 years,
and i have had my truck for about the same amount of time. I'll do my best to put the pictures in order. some may be missing, as most were uploaded to PB's website. ok let me go ahead and get started!!
My Build Thead (Project Slow Motion) |
08-06-2014, 10:16 PM | #2 |
Kvn1011
Re: Kevin's 1972 build thread (slow motion)
08-06-2014, 10:21 PM | #3 |
Kvn1011
08-06-2014, 10:21 PM | #4 |
Kvn1011
08-06-2014, 10:33 PM | #5 |
Kvn1011
i finally got it running after getting a 600cfm holley carb.
I never did drive it because i didnt have a lot of confidence in it being safe ok folks so thats what i started with! very rough!! My family thought i was crazy! but i laughed to myself knowing that i had ordered my dropmember from nate and my rear suspension from chris alston chassisworks (Kp components) ok so Now, on to the next set of pictures!!
08-06-2014, 10:41 PM | #6 |
Kvn1011
08-06-2014, 10:45 PM | #7 |
Kvn1011
oops!! got paint on my brothers driveway lol
i ended up getting a metal etching primer and hit it with a satin black finish it came out pretty good! i painted all the PB stuff this way
08-06-2014, 10:47 PM | #8 |
Kvn1011
next up,
i cleaned the frame, primer and then por15 i originally had this bright idea to use the silver por15 but i dont think i mixed it up good enough and ended up going with the black instead and since i was working with limited time and space at my brothers garage i only painted the area that i could reach, without removing the cab i ended up covering the frame completly with por15 at a later date
My Build Thead (Project Slow Motion) Last edited by kvn1011; 08-06-2014 at 11:01 PM. |
08-06-2014, 11:01 PM | #9 |
Kvn1011
08-06-2014, 11:09 PM | #10 |
Kvn1011
08-06-2014, 11:23 PM | #11 |
Kvn1011
so, i made a decision to go with 1973 c10 lower control arms and have someone fab up a airbag cup/bracket to use with my dropmember,
well that all changed after finding out that MMW, michigan metalworks were creating C10 arms, ***also got new wheel bearings and rotors
08-06-2014, 11:43 PM | #12 |
Kvn1011
i really really want 22's for the front
but, that will have to wait i had these wagon wheels laying around and just went with them for the mean time i may eventually switch to 15's and wide white walls when i get closer to completion i had to trim the wheel well just a little lol front is done and the rear is up next i have since moved to a new house, and tried to finish the rear in speedy fashion
My Build Thead (Project Slow Motion) Last edited by kvn1011; 08-06-2014 at 11:48 PM. |
08-06-2014, 11:47 PM | #13 |
Kvn1011
08-07-2014, 12:00 AM | #14 |
Kvn1011
some time during my build i went to TN with a good friend of mine
we ended up meeting Lucky Brewer, stayed at his place for the night, met his wife and kids, and i learned about congenitial heart defects, in which his daughter Lilie had i put the sticker on my truck, but i only found a pic of luckys truck, but later we went to Layd out at the park, it was a cool show |
08-07-2014, 12:08 AM | #15 |
Kvn1011
08-07-2014, 12:09 AM | #16 |
Kvn1011
08-07-2014, 12:11 AM | #17 |
Kvn1011
I still don't have the front rack and pinion braces welded in, or the step notch brace welded in, i actually wasnt planning on doing any welding,
but, i'll get to that later |
08-07-2014, 12:16 AM | #18 |
Kvn1011
08-07-2014, 12:19 AM | #19 |
Kvn1011
08-07-2014, 12:24 AM | #20 |
Kvn1011
i hope this pump doesnt bite me in the A5S later
i still have the stocker as back up powersteering/alt bracket from speedway, also got the camaro oil pan and pickup tube (not pictured)
08-07-2014, 12:36 AM | #21 |
Kvn1011
08-07-2014, 12:39 AM | #22 |
Kvn1011
Shouts out to Captain FAB!! the rear impala SS kit is awesome
i got the wilwood d52 for the front ((still in box)
08-07-2014, 12:40 AM | #23 |
Kvn1011
08-07-2014, 12:42 AM | #24 |
Kvn1011
08-07-2014, 12:54 AM | #25 |
Kvn1011
this pretty much brings things up to speed
i have done everything myself, and figured i better get a welder so hopefully in the next few days my hobart 125 will arrive i will then attempt to weld the Rack and pinion braces in the bracket for the PB hood assembly, the brace for the rear step notch and then it will be time to run the fuel lines, brake lines raised wood floor for the rear, paint my trans (TH350) i then need to make it to michigan as my uncle says he has new bumpers, a nicer grill, grill surround, rear sliding window and a crackless windshield lol recently got a new core support and doors (AMD) via theBurb out of MN, great guy to deal with still in need of a tailgate and wiring harness
