Someone correct me if I am wrong but it is a fiber optic cable that runs just behind the acrylic piece with "PRND1/2" and then connects to a special bulb socket on the back of the instrument cluster....if it doesn't work make sure the cable is there and not cut then check the bulb....it is a standard bulb you can get at a checkers/schucks/Napa.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Guest
Posts: n/a
its all about the +6 inches
This is true.
Here is the bulb and socket. It should be found on the inner bulb that lights up your speedo. i don't have my fiber optic cable picture anymore, but it knda looks like a h/d black wire that doesn't want to bend very easily. |
