Door hinge pin removal
Any advice on getting the pins out of the door hinges? PB Blaster, vise, and a hammer aren't getting it done. Don't have a torch. Thanks
Re: Door hinge pin removal
3 of my 4 came apart as should 4th one I took to work (did it on my breaks) and milled it out. I then got a bigger pin and bushings for it
I don't have specific experience with 60-66 trucks, but on other years if you cut the pin right in the middle with a cut off wheel they come right out once they are broken into two pieces.
Not sure on earlier years, but I think 67-72 are staked on the bottom. Grind off the rounded head rather than the staked end and drive out with a drift.
Soak them in ATF for a few days. Put them in your oven for an hour at the highest temp. You can get a propane torch for sweating copper at the home store for a few bucks. Heat the hinge, not the pin. Send it to me, I'll get it out. ![]() Just a few ideas. |
